How to require headers for route?
I want to require an Authorization header for a route.
But I can’t match the route with this curl:
curl -H "Authorization: 123" http://localhost:8080/abc/
401 Not authorized abc
curl -H "Authorization: 123" http://localhost:8080/def/
401 Not authorized def
What am I doing wrong?
And is there a better way to write this config?
v2.9.0-beta.2
:8080 {
	handle /abc/* {
		@rbac <<CEL
		(header({'Authorization': ['123']})) ||
		(header({'Authorization': ['234']}))
		CEL
		reverse_proxy @rbac {
			to server1:3000
		respond "401 Not authorized abc" 401
	handle /def/* {
		@def {
			header Authorization 123
		reverse_proxy @def {
			to server1:3000
		respond "401 Not authorized def" 401
		reverse_proxy {
			to server1:3000
Works for me:
:8881 {
	@rbac <<CEL
		header({'Authorization': ['123', '234']})
		CEL
	respond @rbac "OK"
	respond "NOT OK"
$ curl -H'Authorization: 1234' http://localhost:8881
NOT OK
$ curl -H'Authorization: 123' http://localhost:8881
OK
Oh your issue is with directive order: Caddyfile Directives — Caddy Documentation
respond has a higher directive order so it always gets sorted before reverse_proxy within the same context. You can wrap them in handle to control the order they run in. See the docs.
