I am trying to redirect (302) from / to /en/. Just that.
I tried putting this in my config
http://127.0.0.1:8543 {
redir / /en/ 302
But this redirects everything to /en/, including/en/ itself, causing a circular redirect:
$ curl -I http://127.0.0.1:8543/en/
HTTP/1.1 302 Found
After some investigation I discovered it is in fact behaving as documented :
from is the request path to match (it must match exactly, except for /, which is a catch-all).
It’s seeing / as a catch-all, and so redirect everything to the target. However, I can’t work out any way to ask it to redirect just/. Is there any way to achieve this?
In the past I’ve used an if statement to double check the request was for / exactly.
I don’t have the config I used, but I believe something like this:
redir {
/ /en/ 302
if {uri} is /
Should work (unless URI comes back as empty, I can’t remember right now). Worst case scenario you can check for if {request} ends_with your.domain.com/ to be super explicit about it and will definitely work.
