netqyq
(Yongqiang)
#1
How to redirect a path like following?
redirect from /db/*
to /db/mongodb/*
Why path_regexp
is unrecognized?
My Caddyfile
abc.com {
root * /root/webroot
path_regexp mongodb (^m.*mongo.*\/$)
redir /dt/{re.mongo.1} /dt/mongodb/{re.mongo.1}
Ubuntu 20.04.1 (no docker)
./caddy reload
2022/02/09 05:26:03.194 INFO using adjacent Caddyfile
reload: adapting config using caddyfile: Caddyfile:33: unrecognized directive: path_regexp```
matt
(Matt Holt)
#2
netqyq
(Yongqiang)
#3
My need is that redirect from /db/*
to /db/mongodb/*
but I don’t know how to do it.
redir <matcher> to
As Matt said, you’re not using the correct syntax to define a named matcher. Please review the docs he linked.
Your regexp is also incorrect. You probably want something like this:
@mongo path_regexp mongo ^/db/(.*)
rewrite @mongo /db/mongodb/{re.mongo.1}
matt
(Matt Holt)
#6
Thanks Francis; I was mobile so typing out the whole solution would have been a bit tedious. So I’m glad you did!
system
(system)
closed
#7
