How to "pass-thru" destination ports?
I’m trying to run a server that utilizes websockets on a random high port. The port number would be within the range 49152-65535.
As far as I can tell, caddy has no way to “pass-thru” a port number to the upstream without using the layer 4 module, which I don’t want to do as that would remove TLS.
Feb 28 00:52:30 caddy systemd[1]: Reloading caddy.service - Caddy...
░░ Subject: A reload job for unit caddy.service has begun execution
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ A reload job for unit caddy.service has begun execution.
░░ The job identifier is 7286.
Feb 28 00:52:30 caddy caddy[5914]: {"level":"info","ts":1740721950.87227,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Feb 28 00:52:30 caddy caddy[5914]: Error: adapting config using caddyfile: parsing key: invalid port '49152-65535': strconv.Atoi: parsing "49152-65535": invalid syntax
Feb 28 00:52:30 caddy systemd[1]: caddy.service: Control process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ An ExecReload= process belonging to unit caddy.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Feb 28 00:52:30 caddy systemd[1]: Reload failed for caddy.service - Caddy.
░░ Subject: A reload job for unit caddy.service has finished
░░ A reload job for unit caddy.service has finished.
░░ The job identifier is 7286 and the job result is failed.
Currently running caddy in a debian LXC container on Proxmox using the community script from here: Proxmox VE Helper-Scripts
OS: Debian
Caddy is running as a systemd service.
# caddy.service
# for your installation.
Type=notify
# domain name.
    email <redacted>
archipelago.cryptospartan.net:443 {
    reverse_proxy http://10.0.12.19
archipelago.cryptospartan.net:49152-65535 {
    @websockets {
        header Connection *Upgrade*
        header Upgrade    websocket
    reverse_proxy @websockets http://10.0.12.19:49152-65535
Do you mean you want to use the same port number on which the request is received? Your upstream address can be reverse_proxy @websockets http://10.0.12.19:{port}
Not true. The layer-4 module can receive TLS traffic, inspect the SNI (without TLS termination), and proxy it as-is to upstream.
Yes this is what I’m looking for! But when I do this:
    reverse_proxy http://10.0.12.19:80
    @websockets {
Caddy fails to start and I get this error:
Mar 02 21:05:14 caddy caddy[4698]: Error: adapting config using caddyfile: parsing caddyfile tokens for 'reverse_proxy': parsing upstream 'http://10.0.12.19:{http.request.port}': due to parsing difficulties, placeholders are not allowed
when an upstream address contains a scheme, at /etc/caddy/Caddyfile:27
Mar 02 21:05:14 caddy systemd[1]: caddy.service: Control process exited, code=exited, status=1/FAILURE
Also, In regards to this:
Caddy is handling all of the TLS for this service, the upstream doesn’t support it. So in this case, I don’t believe layer-4 would solve my issue.
The error message means you need to remove the http:// from here. Caddy assumes http in reverse_proxy.
The Caddyfile format does not support port range here, so you will have to use JSON.
I converted the config to JSON by:
1- removing the port range, keeping the starting port only
2- removing http:// from the reverse_proxy upstream address
3- running caddy adapt -p to get the JSON equivalent.
4- inserting the port range into the binding address.
Here’s the result:
	"apps": {
		"http": {
			"servers": {
				"srv0": {
					"listen": [
						":443"
					"routes": [
							"match": [
									"host": [
										"archipelago.cryptospartan.net"
							"handle": [
									"handler": "subroute",
									"routes": [
											"handle": [
													"handler": "reverse_proxy",
													"upstreams": [
															"dial": "10.0.12.19:80"
							"terminal": true
				"srv1": {
					"listen": [
						":49152-65535"
					"routes": [
							"match": [
									"host": [
							"handle": [
									"routes": [
											"handle": [
													"upstreams": [
															"dial": "10.0.12.19:{http.request.port}"
											"match": [
													"header": {
														"Connection": [
															"*Upgrade*"
														"Upgrade": [
															"websocket"
							"terminal": true
