v2.4.1
I use CaddyFile
ubuntu 20.04
systemctl start caddy
example.com {
output file /var/log/caddy.log
handle /js/* {
root * /usr/share/smokeping/www/js
handle /css/* {
root * /usr/share/smokeping/www/css
handle /cache/* {
root * /var/cache/smokeping
handle /images/* {
root * /usr/share/smokeping/www/images
reverse_proxy unix//var/run/fcgiwrap.socket {
transport fastcgi {
split ""
env SCRIPT_FILENAME /usr/share/smokeping/smokeping.cgi
Now I can access the smokeping webpage. But all js, css, image resources are 404 Not Found. I’m sure the path in the caddyfile is correct. What did I do wrong?
404 Not Found.
