How to get wildcard certificate for entire subdomain
1. Caddy version : v2.2.0
Caddyfile in /etc/caddy/Caddyfile
Ubuntu 20
 *.maindomain.com, othersubdomain.com
root * /home/<user>/<dir>
file_server browse
@notStatic {
        not path /static/*
reverse_proxy @notStatic localhost:8000
tls <email> {
       dns cloudflare <API>
       on_demand
3. The problem Im having:
All my wildcard subdomains are giving ERR_TIMED_OUT
Some of the subdomains are having a certificate issued and works fine. While others are giving this time out. I want to issue a single certificate to all wildcard subdomains and still support the otherdomain.
Oct 06 00:41:10 maindomain caddy[238708]: {"level":"info","ts":1601937670.4078476,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/<some_id>"}
Oct 06 00:41:10 maindomain caddy[238708]: {"level":"info","ts":1601937670.4084172,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["subdomain.maindomain.com"]}
Oct 06 00:41:13 maindomain caddy[238708]: {"level":"info","ts":1601937673.2709827,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["subdomain.maindomain.com"]}
Oct 06 00:41:14 maindomain caddy[238708]: {"level":"info","ts":1601937674.2175426,"logger":"tls.obtain","msg":"releasing lock","identifier":"subdomain.maindomain.com"}
Oct 06 00:41:14 maindomain caddy[238708]: {"level":"info","ts":1601937674.369648,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"subdomain.maindomain.com"}
Oct 06 00:41:14 maindomain caddy[238708]: {"level":"info","ts":1601937674.3703494,"logger":"tls.obtain","msg":"acquiring lock","identifier":"subdomain.maindomain.com"}
Oct 06 00:41:14 maindomain caddy[238708]: {"level":"info","ts":1601937674.370565,"logger":"tls.obtain","msg":"lock acquired","identifier":"subdomain.maindomain.com"}
Oct 06 00:41:14 maindomain caddy[238708]: {"level":"info","ts":1601937674.372699,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["subdomain.maindomain.com"]}
  • Added Cloudflare API key for DNS : didn’t help.
Try removing on_demand; it’s not needed for wildcards. (And not recommended except in very special cases.)
It worked, thanks.
But I want to add more external extra domains the future (custom domain feature for the product), that’s why I added the on_demand part, what do I do in that case?
I think you should make a separate site block to handle on-demand TLS. Maybe something like this:
	on_demand_tls {
		ask http://example.com/ask
(common-site) {
	root * /home/user/dir
	file_server browse
	@notStatic not path /static/*
*.maindomain.com, othersubdomain.com {
	import common-site
	tls foo@example.com {
		dns cloudflare {$CLOUDFLARE_API_KEY}
:443 {
	import common-site
		on_demand
That’s worth a shot. This might also be more elegant in the JSON.
