WoJ
(WoJ)
September 14, 2022, 10:59am
#1
I would like to ensure that only whitelisted URIs are accepted by Caddy on a static site.
Today, the fully open site is defined as
https://hello.example.com {
root * /path/to/site/dir
It works great, https://hello.example.com/afile.txt
is retrieved correctly.
I now would like to make the following restrictions:
the content of the directory stays as it: afile.txt
and anotherfile.txt
afile.txt
is available through https://hello.example.com/asecretstringhardtoguess/afile.txt
anotherfile.txt
and anything else is not available at all
In other words, you have to know asecretstringhardtoguess
to build the URI for a specific file.
How can I approach that?
Version 2: if the setup above is too complicated, having a common asecretstringhardtoguess
-based URI for all files would be OK too:
https://hello.example.com/asecretstringhardtoguess/anotherfile.txt
are available, but not https://hello.example.com/afile.txt
or https://hello.example.com/anotherfile.txt
I’m not sure what you’re trying to do here… But “security through obscurity” is not a good way to go. Why do you want to do this?
Realize that crawlers may still find the files if it ever gets linked to from elsewhere.
WoJ
(WoJ)
September 16, 2022, 11:32am
#3
Yes, I am really aware of that (as an infosec professional). I want to put a layer of protection on data that is quasi-public anyway.
But my question was not really about “should I do it” or “is it safe”, but rather “is it doable”?
Whitestrake
(Matthew Fay)
September 16, 2022, 12:01pm
#4
Why not simply place the files in the directory /path/to/site/dir/asecretstringhardtoguess/
Whitestrake
(Matthew Fay)
September 16, 2022, 12:16pm
#5
Version 1:
example.com {
@secretpaths {
path /asecretstringhardtoguess/afile.txt
path /adifferentstringentirely/anotherfile.txt
handle @secretpaths {
uri strip_prefix /asecretstringhardtoguess
uri strip_prefix /adifferentstringentirely
We declare a strict (non-globular) list of paths that we allow in @secretpaths
Then we handle all the paths we’ve allowed, first stripping all the possible secret strings (throwing a full set of URI stripping at every request shouldn’t be much of a bother at all for the CPU because these are simple string manipulations and I don’t envision you’ll have a lot of these…)
The secret strings are double handled, but by allowlisting entire paths, we prevent any cross-secretstring-requests because our allowlist items contain a 1:1 secret to requested file relationship.
Version 2:
example.com {
handle_path /asecretstringhardtoguess/* {
This version simply requires (and then strips) the asecretstringhardtoguess
as the first path element for any request to successfully be routed to the file server.
WoJ
(WoJ)
September 16, 2022, 4:33pm
#6
Ahhhhh… this is how one misses obvious solutions by thinking out of the box Thank you.
And thank you for the solutions in your other post as well!
system
(system)
Closed
October 14, 2022, 10:59am
#7
