2.4.1
Host - Ubuntu 20.04.2 LTS
Docker Desktop version - 20.10.6
Caddy container - caddy:latest
docker-compose up -d
version: '3.8'
image: xcaddy:latest
- 443:443
- wg-pia
- TZ=America/Chicago
- PUID=1000
- PGID=1000
- CADDY_DOCKER_CADDYFILE_PATH=/data/CaddyFile
- "${docker}/caddy2/data:/data"
- "${docker}/caddy2/config:/config"
labels:
- com.centurylinklabs.watchtower.enable=false
https_port 443
http_port 80
format console
The container logs are displayed in json rather than console format.
There are no error messages present in the container logs. They are just being displayed in json instead of console format.
Searched the docs and the formum and I think I am using the correct syntax in the Caddyfile global block based on what I have read. Copied verbatim from the docs, but does not seem to be working for me. Guessing I am not understanding the docs correctly.
