Hi,
I want to fully disable TLS. Caddy appears to be ignoring the “tls off” directive.
Here’s a minimal Caddyfile (this is the whole thing), with a FQDN. This is not an externally reachable host, but the domain resolves on my intranet DNS:
PHLLT8526.middleearth.home:8080
tls off
When I run this, Caddy ignores the directive disabling TLS and attempts to provision a cert for the site:
704)~/tmp % ./caddy
Activating privacy features…
Your sites will be served over HTTPS automatically using Let’s Encrypt.
By continuing, you agree to the Let’s Encrypt Subscriber Agreement at:
https://letsencrypt.org/documents/LE-SA-v1.0.1-July-27-2015.pdf
Please enter your email address so you can recover your account if needed.
You can leave it blank, but you’ll lose the ability to recover your account.
Email address: ^C%
Why? How do I force Caddy to not use TLS?
Thanks
