Hi All,
I have just come across Caddy and it looks like it will be more than capable of handling the simple case that I need.
Currently, I am trying to work my way through the documentation and on the hunt for a simple example of a way take a some website on the same machine and have a main site and subdomains for the others.
As an example, I want:
www.example.com (main site) — static pages
docs.example.com (subdomain) — web pages in a separate directory
explorer.example.com (subdomain) — web pages in a separate directory
and other subdomains under example.com
How can I easily set up a caddy config for this so that have them all under a LetsEncrypt certificate (HTTPS) and basically the whole website looks homogeneous to the user.
I am sure that this is a simple and common case, but if someone could please guide me in the right direction or show me an similar type example then that would be of huge help.
I am also guessing that I could go into the main director and just do a “caddy run” or something like that to start it all up, correct.
Sorry for still being very new to Caddy
