How to configure a specific route
I have following Caddy config:
(blitzNoQueryString) {
      @blitzCache {
                method GET
                not expression {query} != ''
        route @blitzCache {
                try_files /cache/blitz/{host}{uri}/index.html {path} {path}/index.php?{query}
So if the url doesnt contains any req. params, the blitzCache route will be used. What I actually want is that the blitzCache route should be used regardless of any req. params but those following two:
.) x-craft-live-preview
.) x-craft-preview
May somboady has a hint how to achieve this?
Option 1: Both x-craft-live-preview AND x-craft-preview are not present at the same time:
 @blitzCache {
    method GET
    not query x-craft-live-preview=* x-craft-preview=*
For example,
  • ?x-craft-live-preview will match
  • ?x-craft-preview will match
  • ?x-craft-live-preview&x-craft-preview won’t match
  • ?anything-else will match
Option 2: Neither x-craft-live-preview NOR x-craft-preview is present:
 @blitzCache {
    method GET
    not query x-craft-preview=*
For example,
  • ?x-craft-live-preview won’t match
  • ?x-craft-preview won’t match
Hi, I tried option 2, but still caddy skips the blitzCache route if any req. params is present. Any ideas?
Hi, I tried option 2 but still caddy skips the blitzCache route if any req. param is present. Any ideas?
I can’t seem to reproduce your issue, sorry.
Here’s my quick-n-dirty Caddyfile:
	http_port 8080
:8080 {
	@blitzCache {
		method GET
	route @blitzCache {
		respond "Route 'blitzCache': yes"
	respond "Route 'blitzCache': no"
$ caddy run --config Caddyfile
And here are my curl tests:
$ curl http://localhost:8080
$ curl http://localhost:8080/?foo=bar
$ curl http://localhost:8080/?x-craft-live-preview
$ curl 'http://localhost:8080/?x-craft-live-preview&foo=bar'
$ curl http://localhost:8080/?x-craft-preview
$ curl 'http://localhost:8080/?x-craft-preview&foo=bar'
$ curl 'http://localhost:8080/?x-craft-live-preview&x-craft-preview'
$ curl 'http://localhost:8080/?x-craft-live-preview&x-craft-preview&foo=bar'
As long as the request doesn’t include x-craft-live-preview or x-craft-preview, I get:
Otherwise, I get:
So, the routing logic based on the presence (or absence) of x-craft-live-preview or x-craft-preview seems to be working fine on my end.
Hi, I know now why it doesnt work at my end, we have a reverse proxy setup so our query params are stored in http.request.header.x-orig-query
But caddy throws an error for following config block.
@blitzCache {
method GET
not {http.request.header.x-orig-query} x-craft-live-preview=*
not {http.request.header.x-orig-query} x-craft-preview=*
{“level”:“info”,“ts”:1740404912.2124543,“msg”:“using config from file”,“file”:“/data/etc/Caddyfile”}
Error: adapting config using caddyfile: getting matcher module ‘{http.request.header.x-orig-query}’: module not registered: http.matchers.{http.request.header.x-orig-query}, at /xxx/Caddyfile:41 import chain [‘/xxx/Caddyfile:79 (import blitzNoQueryString)’]
May somebody knows how to solve this?
This is invalid. What is the not supposed to act on? The not matcher takes another matcher to negate. What matcher is it taking?
You need to check either header or var
What @Mohammed90 said here - use either header or var.
Caddyfile
	http_port 8080
:8080 {
	@blitzCache {
		method GET
		not header x-orig-query *x-craft-live-preview*
		not header x-orig-query *x-craft-preview*
	route @blitzCache {
Test:
$ curl http://localhost:8080 -H 'x-orig-query: foo=bar'
$ curl http://localhost:8080 -H 'x-orig-query: x-craft-live-preview'
$ curl http://localhost:8080 -H 'x-orig-query: x-craft-live-preview&foo=bar'
$ curl http://localhost:8080 -H 'x-orig-query: x-craft-live-preview&x-craft-preview'
$ curl http://localhost:8080 -H 'x-orig-query: x-craft-live-preview&x-craft-preview&foo=bar'
