I know and I totally agree with you, @matt. I was simply asking about the feasibility of this in Caddy Server, but really, if one wanted to provide a catch all certificate it would be as simple as generating it manually and using the tls
directive.
I can think of a case where it may become useful. For example, if we try to access by IP to a web service using https. It’s a rare and extreme case, I know. But it’s for thinking about the small details. For example, in the case of Google an invalid certificate is returned and, as soon as the client accepts the risk, it is redirected to google.com.
~ ❯ nslookup google.com
Server: 1.1.1.1
Address: 1.1.1.1#53
Non-authoritative answer:
Address: 142.250.184.174
~ ❯ openssl s_client -showcerts -connect 142.250.184.174:443
Connecting to 142.250.184.174
CONNECTED(00000003)
Can't use SSL_get_servername
depth=0 OU=No SNI provided; please fix your client., CN=invalid2.invalid
verify error:num=18:self-signed certificate
verify return:1
verify return:1
Certificate chain
0 s:OU=No SNI provided; please fix your client., CN=invalid2.invalid
i:OU=No SNI provided; please fix your client., CN=invalid2.invalid
a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
v:NotBefore: Jan 1 00:00:00 2015 GMT; NotAfter: Jan 1 00:00:00 2030 GMT
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Server certificate
subject=OU=No SNI provided; please fix your client., CN=invalid2.invalid
issuer=OU=No SNI provided; please fix your client., CN=invalid2.invalid
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 1386 bytes and written 382 bytes
Verification error: self-signed certificate
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Protocol: TLSv1.3
Server public key is 2048 bit
This TLS version forbids renegotiation.
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 18 (self-signed certificate)
~ ❯ curl -I -k https://142.250.184.174
HTTP/2 301
content-type: text/html; charset=UTF-8
date: Sat, 14 Dec 2024 00:44:03 GMT
expires: Mon, 13 Jan 2025 00:44:03 GMT
cache-control: public, max-age=2592000
server: gws
content-length: 219
x-xss-protection: 0
x-frame-options: SAMEORIGIN
alt-svc: h3=":443"; ma=2592000,h3-29=":443"; ma=2592000
As I said, I’m not trying to convince anyone about whether this is a good idea or not. Obviously, having the possibility to use on-demand TLS, this may not make sense as you could end up with the same behavior or even a better one.
Regards.
