How to clear all data caddy produced on mac after uninstall?
I’m using Caddy by directly downloading the binary file, and I’m also using features like a local HTTPS certificate. I’m wondering if this creates some files in certain folders on my Mac? I want to completely clear the data after deleting the Caddy binary file.
null
null
download the bin file and run by full path
macOS Tahoe
null
null
null
null
null
null
You can check the directories noted in our documentation:
But since most of the help template is left empty, I can’t be sure that this answer is sufficient in your case.
