Debian 10, Linux 4.19.0-14-amd64 #1 SMP Debian 4.19.171-2 (2021-01-30) x86_64 GNU/Linux
Just an officially systemd service file
If command on terminal will be OK, it outputs console format as I wish.
# /lib/systemd/system/caddy.service
# caddy.service
# for your installation.
Group=srv
; Environment=XDG_DATA_HOME=/var
; Environment=XDG_CONFIG_HOME=/var
None about config file, I think. Just question for how to change caddy itself’s output log format
Cannot set caddy itself’s log format.
Current journalctl caddy.service
log look like this, JSON format, human unfriendly:
Apr 19 02:44:23 srv caddy[32659]: {"level":"info","ts":1618771463.3738742,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Apr 19 02:44:23 srv caddy[32659]: {"level":"info","ts":1618771463.384001,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["127.0.0.1:2019","localhost:2019","[::1]:2019"]}
Apr 19 02:44:23 srv caddy[32659]: {"level":"info","ts":1618771463.3851924,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Apr 19 02:44:23 srv caddy[32659]: {"level":"info","ts":1618771463.3854547,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv1"}
Apr 19 02:44:23 srv caddy[32659]: {"level":"info","ts":1618771463.3865013,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000306000"}
I have been read all reletave documents but looks only JSON file define log format, but I use caddyfile.
