Docker image caddy:2.4.3
System environment:
Docker
Service/unit/compose file:
version: '3'
web:
build: .
image: caddy:2.4.3
- ./docker/caddy/Caddyfile:/etc/caddy/Caddyfile
- ./files/media:/data/media
- ./files/static:/data/static
- ./files/caddy:/data/caddy
depends_on:
- web
http://example.com {
@denied path_regexp .+\.scss
handle @denied {
error 403
handle_path /media/* {
root * /data/media
handle_path /static/* {
root * /data/static
reverse_proxy web:8080
My webserver is behind Caddyserver, and some static files serve in the /static/
and /media/
directory.
Meanwhile some sensitive files are also putted in the /static/
directory, like /static/css/app.scss
, I have to block them, so I write something like that:
handle @denied {
error 403
If I request http://example.com/other/path/app.scss
, a “403 Forbidden” is returned, it is my expected result.
But if I request http://example.com/static/css/app.scss
, the file app.scss
is returned as usual.
I think the order of handle
directive is confused.
I tried another solution, putting the error
directive into the static handler:
root * /data/media
error @denied 403
root * /data/static
reverse_proxy web:8077
It didn’t work either.
So how can I solve this problem? Thank you!
