sajils
(Sajil Joseph)
1
Please find my caddy file below. Can you suggest the exact format to include robots.txt
*.example.com { tls /etc/letsencrypt/live/example.com/fullchain.pem /etc/letsencrypt/live/example.com/privkey.pem log { hostnames 1.example.com output file /var/log/caddy/1.example.com.log } @1 host 1.example.com handle @1 { reverse_proxy localhost:007 }
Please fill out the help topic template, as per the forum rules.
And please mind your formatting, use code blocks. Your config is impossible to read because it lost its formatting.
sajils
(Sajil Joseph)
3
*.example.com {
sajils
(Sajil Joseph)
4
Any help would be appreciated
You didn’t fill out the help topic template, as requested.
It’s a forum rule.
system
(system)
Closed
6
