I have a URL https://example.com/file.txt
which serves a file. Access to the file is authenticated via a bearer (a key in the headers).
The problem is that example.com
does not sets the CORS header and I cannot access file.txt
from JavaScript in a browser.
One possibility is to fix the site. This is not readily feasible.
One other possibility I was considering is to use caddy
as a proxy which would
- pass the request to the server (together with all the headers, including the authentication one above)
- provide in return to the browser CORS headers which would allow for access from the browser
I was hoping that
proxy / https://example.com {
cors
log stdout
errors stderr
would be enough but I guess that cors
is for cases when caddy
acts as the primary server (and not a proxy).
Is there a way to achieve such CORS-enabling proxification?
EDIT: I see that a “welcome back” header is added to the post:
Yes, I am comniog back to caddy
after two years of wandering in less friendly waters
