I’m considering porting a legacy system to caddy. What makes this different is that the router stuff is not inside the framework but using the server alias and rewriting rules.
What happens when i put a thousand fast (non regexpr) rewrite and a handful of dynamic (with regexpr) rules (all having different basepaths) into the server config file? Is this a O(n) operation or are you doing something better like binary or radix search?
And by the way, what are the precedence rules among rules? This is a serious part missing in the documentation.
Does the longest prefix wins? Are simple rewrites (please call them aliases as any other server does) picked up before the regexpr?
I haven’t benchmarked or profiled the rewrite middleware. It’ll probably undergo some significant changes either before or just after 1.0 as we optimize things and I have plans to make a standard method of request matching for directives, that will allow matching more easily than just based on path.
The rewrite directive chooses the rule with a base request path of longest length. We can probably mention this in the docs, although I was hoping this was part of “it just works” that people would expect.
