Hi all,
Hoping someone can provide a little education on how proxies impact the ability for some webapps to share the same session across tabs (firefox, chrome) without re-authenticating.
For example, Sonarr and Radarr work fine when opening a link in a new tab, but if I try the same in Plex or Portainer, I have to re-authenticate. Remove the proxy and I no longer have to re-authenticate new tabs for Plex or Portainer.
I’m not a web developer but am guessing this behavior has to do with how the webapp is handling session data? How does one go about troubleshooting this type of issue?
Below is a snippet of my caddyfile covering portainer:
(options) {
gzip
timeouts none
realip {
from cloudflare
from 10.0.0.0/8
from 172.16.0.0/12
from 192.168.0.0/16
(tls) {
tls email@example.com {
protocols tls1.1 tls1.2
#ca https://acme-staging-v02.api.letsencrypt.org/directory
(block_external_at_root) {
ipfilter / {
rule allow
ip 192.168.0.0/16
ip 172.16.0.0/12
ip 10.0.0.0/8
portainer.example.com {
import block_external_at_root
import options
import tls
proxy / http://portainer:9000 {
websocket
insecure_skip_verify
log / /var/logs/sites/app/portainer-access.log {$LOG_LONG}
errors /var/logs/sites/app/portainer-errors.log
