yosefy
(Yosef Yudilevich)
1
how can i make http default protocol in Caddyfile http
so if i write
testsite {
and caddy will use http and not https by default
i am aware of option with http:// in the beginning of site but it makes visual noise in conf
i couldn’t find such option in global config section in docs
thanks
That’s the exact way to do it.
Caddy is HTTPS by default, if you want to override that, you need to explicitly tell Caddy about the override.
system
(system)
Closed
3
