Im running caddy ingress in k8s to serve a php-fpm container. I only get 502 responses. You can see it here: https://homolog.main-api.fretegestao.com.br/
I have a golang image running in this cluster, and it is working fine as it doesnt need fastcgi.
I didnt find how to use a custom caddy configuration in the ingress or how to use the fastcgi directive in the yaml in the docs. GitHub - caddyserver/ingress: WIP Caddy 2 ingress controller for Kubernetes
I need to use fastCGI for this container, how can i do that?
Deployment and service yaml:
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app: main-api
spec:
replicas: 1
strategy:
type: RollingUpdate
rollingUpdate:
maxUnavailable: 0
maxSurge: 2
selector:
matchLabels:
app: main-api
template:
metadata:
labels:
app: main-api
spec:
containers:
- name: main-api
image: <image>
- containerPort: 9000
envFrom:
- configMapRef:
apiVersion: v1
kind: Service
metadata:
spec:
selector:
app: main-api
- name: fpm
port: 9000
targetPort: 9000
Ingress yaml
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
annotations:
kubernetes.io/ingress.class: caddy
spec:
rules:
- host: homolog.main-api.fretegestao.com.br
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 9000
Curl from inside the container pod: (This one does not pass by caddy, its using http instead of fastcgi, thats the explation for the error)
* Trying 127.0.0.1:9000...
* Connected to localhost (127.0.0.1) port 9000 (#0)
> GET / HTTP/1.1
> Host: localhost:9000
> User-Agent: curl/8.0.1-DEV
* Recv failure: Connection reset by peer
* Closing connection 0
curl: (56) Recv failure: Connection reset by peer
pod description:
Namespace: default
Priority: 0
Service Account: default
Node: pool-q5an7/10.116.0.6
Start Time: Thu, 23 Mar 2023 16:59:37 -0300
Labels: app=main-api
pod-template-hash=7cd9d47886
Annotations: kubectl.kubernetes.io/restartedAt: 2023-03-23T16:59:37-03:00
Status: Running
IP: 10.244.0.126
IPs:
IP: 10.244.0.126
Controlled By: ReplicaSet/main-api-deployment-7cd9d47886
Containers:
main-api:
Container ID: containerd://04b6d8f62295e174ed196b0ad0b3002fe0b37c64faafe9cfd623abb4e98a30c7
Image: ...
Image ID: ...
Port: 9000/TCP
Host Port: 0/TCP
State: Running
Started: Thu, 23 Mar 2023 16:59:40 -0300
Ready: True
Restart Count: 0
Environment Variables from:
main-api ConfigMap Optional: false
Environment: <none>
Mounts:
/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-54c4q (ro)
Conditions:
Type Status
Initialized True
Ready True
ContainersReady True
PodScheduled True
Volumes:
kube-api-access-54c4q:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional: <nil>
DownwardAPI: true
QoS Class: BestEffort
Node-Selectors: <none>
Tolerations: node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events: <none>
service description:
Namespace: default
Labels: <none>
Annotations: <none>
Selector: app=main-api
Type: ClusterIP
IP Family Policy: SingleStack
IP Families: IPv4
IP: 10.245.139.92
IPs: 10.245.139.92
Port: fpm 9000/TCP
TargetPort: 9000/TCP
Endpoints: 10.244.0.126:9000
Session Affinity: None
Events: <none>
pod logs: (Im using laravel)
- Installing ezyang/htmlpurifier (v4.16.0): Extracting archive
- Installing phpoffice/phpspreadsheet (1.28.0): Extracting archive
- Installing spatie/laravel-package-tools (1.12.1): Extracting archive
- Installing spatie/laravel-activitylog (4.7.3): Extracting archive
84 package suggestions were added by new dependencies, use `composer suggest` to see details.
Generating optimized autoload files
58 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
Nothing to migrate.
Configuration cache cleared!
Configuration cached successfully!
Route cache cleared!
Routes cached successfully!
Files cached successfully!
Application cache cleared!
> Illuminate\Foundation\ComposerScripts::postAutoloadDump
> @php artisan package:discover --ansi
Discovered Package: fruitcake/laravel-cors
Discovered Package: laravel/sanctum
Discovered Package: laravel/tinker
Discovered Package: nesbot/carbon
Discovered Package: nunomaduro/collision
Discovered Package: spatie/laravel-activitylog
Package manifest generated successfully.
Generated optimized autoload files containing 5701 classes
Compiled views cleared!
Compiled services and packages files removed!
[23-Mar-2023 20:01:20] NOTICE: [pool www] 'user' directive is ignored when FPM is not running as root
[23-Mar-2023 20:01:20] NOTICE: [pool www] 'group' directive is ignored when FPM is not running as root
[23-Mar-2023 20:01:20] NOTICE: fpm is running, pid 289
[23-Mar-2023 20:01:20] NOTICE: ready to handle connections
Ingress description:
Labels: <none>
Namespace: default
Address: ...
Ingress Class: <none>
Default backend: <default>
Rules:
Host Path Backends
homolog.go.fretegestao.com.br
/ go-service-service:80 (10.244.0.76:80)
/ main-api-service:9000 (10.244.0.126:9000)
Annotations: kubernetes.io/ingress.class: caddy
Events: <none>
Error in the caddy pod:
{"level":"error","ts":1679639705.9354064,"logger":"http.log.error","msg":"read tcp 10.244.0.86:35710->10.245.139.92:9000: read: connection reset by peer","request":{"remote_ip":"10.244.0.11","remote_port":"1363","proto":"HTTP/1.1","method":"GET","host":"homolog.main-api.fretegestao.com.br","uri":"/Public/home/js/check.js","headers":{"User-Agent":["Mozilla/5.0 (Linux; Android 11; M2004J15SC) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.5060.114 Mobile Safari/537.36"],"Accept":["*/*"],"Accept-Encoding":["gzip"]},"tls":{"resumed":false,"version":771,"cipher_suite":49195,"proto":"","server_name":"homolog.main-api.fretegestao.com.br"}},"duration":0.008618425,"status":502,"err_id":"xg8825qc7","err_trace":"reverseproxy.statusError (reverseproxy.go:1196)"}
K8S
I just followed the guide on the ghub repo to install it in my k8s cluster. I used helm.
helm install \
--namespace=caddy-system \
--repo https://caddyserver.github.io/ingress/ \
--atomic \
--set ingressController.config.email=redacted@email \
caddy \
caddy-ingress-controller
I dont have any caddyfile or custom config as I dont know how to provide it to the ingress. Probably thats how I should be setting up fastCGI to my container. Could not find how to do it in the ingress docs.
