I’m trying to configure Caddy to use the wildcard example with a Digital Ocean DNS challenge and adding client certificate authentication to some but not all hosts in the group, but getting a fatal error from Caddy on startup.
2023/08/11 06:08:24.642 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": "caddyfile"}
Error: adapting config using caddyfile: parsing caddyfile tokens for 'handle': directive 'tls' is not an ordered HTTP handler, so it cannot be used here - try placing within a route block or using the order global option
Using a custom-built Docker image to add the Digital Ocean module.
FROM caddy:2.7-builder AS builder
RUN xcaddy build \
--with github.com/caddy-dns/digitalocean@master
FROM caddy:latest
Docker on Intel-based Synology NAS.
Not applicable.
Not applicable.
acme_dns digitalocean {env.DIGITALOCEAN_API_KEY}
(client_auth) {
client_auth {
mode require_and_verify
trusted_ca_cert_file /config/certs/CA.crt
*.casa.fonseca.org {
@unifi host unifi.casa.fonseca.org
handle @unifi {
reverse_proxy https://172.16.1.1:443 {
header_up Host {host}
tls_insecure_skip_verify
@dsm host dsm.casa.fonseca.org
handle @dsm {
import client_auth
reverse_proxy https://172.16.1.20:5001 {
@assistant host assistant.casa.fonseca.org
handle @assistant {
reverse_proxy 172.16.1.20:8123
@plex host plex.casa.fonseca.org
handle @plex {
reverse_proxy 172.16.1.20:32400
@movies host movies.casa.fonseca.org
handle @movies {
import client_auth
reverse_proxy 172.16.1.20:7878 {
@books host books.casa.fonseca.org
handle @books {
import client_auth
reverse_proxy 172.16.1.20:8787 {
@series host series.casa.fonseca.org
handle @series {
# import client_auth
reverse_proxy 172.16.1.20:8989
@tautulli host tautulli.casa.fonseca.org
handle @tautulli {
import client_auth
reverse_proxy 172.16.1.20:8181
@music host music.casa.fonseca.org
handle @music {
import client_auth
reverse_proxy 172.16.1.20:8686
@bridge host bridge.casa.fonseca.org
handle @bridge {
import client_auth
reverse_proxy 172.16.1.20:8581
@requests host requests.casa.fonseca.org
handle @requests {
reverse_proxy 172.16.1.20:5055
