How can I serve a different project on a <website>/<projectname> URL?
v1.0.3
Digitalocean VPS (Ubuntu).
nohup caddy &
Sadly I have no idea what this means :frowning:
d. My complete Caddyfile:
jossecottenier.tech
proxy /captcha localhost:3001
proxy /contactform localhost:3001
proxy /test localhost:2020
As you can see in my Caddyfile above, I’m trying to get a seperate React project to be served at /test.
The way I tried to do this is serving it via caddy on localhost:2020 and then adding a proxy in the Caddyfile, as you can see above.
No error messages, just 404 not found when I try to visit the URL.
Restarting caddy services, trying to run with caddy instead of nohup caddy &.
(None)
Hi @Josse3, welcome to the Caddy community!
No worries if you don’t have one - these would be methods of having some kind of supervisor run Caddy for you, like systemd or Docker.
Would you mind posting Caddy’s output when you run nohup caddy &? It should go to a file nohup.out in the same directory you run it from.
Also, while Caddy is running, could you post the results of:
curl -IL localhost:2020
curl -IL localhost:2020/test
curl -ILH "Host:jossecottenier.tech" localhost/test
These will give us an idea of what Caddy is doing and what it’s seeing when proxying.
Hi @Whitestrake, thank you for your reply!
nohup.out of the main directory:
Serving HTTPS on port 443
https://jossecottenier.tech
Serving HTTP on port 80
http://jossecottenier.tech
WARNING: File descriptor limit 1024 is too low for production servers. At least 8192 is recommended. Fix with `ulimit -n 8192`.
nohup.out of test directory:
Serving HTTP on port 2020
http://localhost:2020
Output of curl -IL localhost:2020:
HTTP/1.1 200 OK
Accept-Ranges: bytes
Content-Length: 2332
Content-Type: text/html; charset=utf-8
Etag: "pzl43o1ss"
Last-Modified: Fri, 18 Oct 2019 19:14:12 GMT
Server: Caddy
Date: Sat, 19 Oct 2019 13:54:56 GMT
Output of curl -IL localhost:2020/test (actually ‘/ilias’ because ‘test’ was just a placeholder name):
HTTP/1.1 404 Not Found
Server: Caddy
X-Content-Type-Options: nosniff
Date: Sat, 19 Oct 2019 13:56:30 GMT
Content-Length: 14
Output of curl -ILH "Host:jossecottenier.tech" localhost/test (actually /ilias):
HTTP/1.1 301 Moved Permanently
Connection: close
Server: Caddy
Date: Sat, 19 Oct 2019 13:58:21 GMT
HTTP/2 404
content-type: text/plain; charset=utf-8
date: Sat, 19 Oct 2019 13:58:21 GMT
server: Caddy
server: Caddy
x-content-type-options: nosniff
content-length: 14
Thanks in advance for your time!
Ahh, I see, you’ve got two Caddy servers and the backend Caddy at 2020 is just serving files?
By proxying /ilias to the secondary Caddy server, that server is seeing a request for /ilias - but it’s web root is ./ilias - so it’s trying to find a file in ./ilias/ilias relative to the main Caddy and finding nothing - make sense?
Ditch the backend Caddy server and remove the proxy. The “main” Caddy server can serve files out of the subdirectory automatically.
Hi @Whitestrake
Apparently I was doing things in a weird way.
Someone helped me out and I got it working.
Thanks a lot for your time anyways!
