Hi, thanks for your quick answers. I add some informations.
However, I âhelped meâ with Haproxy in front of caddy, which redirects (without termination) all beginning with vpn.07q.de to the vpn-server, and all other parts to caddy.
Not sure if softether would work behind ssl terminating proxy, but it says its HTTP-VPN
Here is the debug output.
Aug 03 21:06:01 proxy caddy[2538]: {"level":"debug","ts":1659553561.6192992,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"vpn.07q.de/tcp"}
Aug 03 21:06:01 proxy caddy[2538]: {"level":"debug","ts":1659553561.6193378,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.07q.de/tcp"}
Aug 03 21:06:01 proxy caddy[2538]: {"level":"debug","ts":1659553561.619343,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.de/tcp"}
Aug 03 21:06:01 proxy caddy[2538]: {"level":"debug","ts":1659553561.6193476,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*"}
Aug 03 21:06:01 proxy caddy[2538]: {"level":"debug","ts":1659553561.6193533,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","sni":"vpn.07q.de/tcp"}
Aug 03 21:06:01 proxy caddy[2538]: {"level":"debug","ts":1659553561.619362,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","server_name":"vpn.07q.de/tcp","remote":"77.22.6.24:50248","identifier":"vpn.07q.de/tcp","cipher_suites":[4866,4867,4865,49196,49200,163,159,52393,52392,52394,49327,49325,49315,49311,49245,49249,49239,49235,49195,49199,162,158,49326,49324,49314,49310,49244,49248,49238,49234,49188,49192,107,106,49267,49271,196,195,49187,49191,103,64,49266,49270,190,189,49162,49172,57,56,136,135,49161,49171,51,50,154,153,69,68,49159,49169,49160,49170,22,19,157,49313,49309,49233,156,49312,49308,49232,61,192,60,186,53,132,47,150,65,7,5,10,255],"cert_cache_fill":0.0004,"load_if_necessary":true,"obtain_if_necessary":true,"on_demand":false}
Aug 03 21:06:01 proxy caddy[2538]: {"level":"debug","ts":1659553561.6194434,"logger":"http.stdlib","msg":"http: TLS handshake error from 77.22.6.24:50248: no certificate available for 'vpn.07q.de/tcp'"}
I canât deliver a curl output, as I donât know how to set the SNI correctly. It will allways set the SNI to vpn.07q.de, which will work.
However, openssl may also be helpfull:
openssl s_client -connect vpn.07q.de:443 -servername vpn.07q.de/tcp
CONNECTED(00000003)
802B08CA6F7F0000:error:0A000438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error:../ssl/record/rec_layer_s3.c:1584:SSL alert number 80
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 316 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
without the false SNI:
CONNECTED(00000003)
depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = vpn.07q.de
verify return:1
Certificate chain
0 s:CN = vpn.07q.de
i:C = US, O = Let's Encrypt, CN = R3
a:PKEY: id-ecPublicKey, 256 (bit); sigalg: RSA-SHA256
v:NotBefore: Aug 3 06:35:49 2022 GMT; NotAfter: Nov 1 06:35:48 2022 GMT
1 s:C = US, O = Let's Encrypt, CN = R3
i:C = US, O = Internet Security Research Group, CN = ISRG Root X1
a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
v:NotBefore: Sep 4 00:00:00 2020 GMT; NotAfter: Sep 15 16:00:00 2025 GMT
2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
i:O = Digital Signature Trust Co., CN = DST Root CA X3
a:PKEY: rsaEncryption, 4096 (bit); sigalg: RSA-SHA256
v:NotBefore: Jan 20 19:14:03 2021 GMT; NotAfter: Sep 30 18:14:03 2024 GMT
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=CN = vpn.07q.de
issuer=C = US, O = Let's Encrypt, CN = R3
Peer signing digest: SHA256
Peer signature type: ECDSA
Server Temp Key: X25519, 253 bits
SSL handshake has read 4158 bytes and written 376 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_128_GCM_SHA256
Server public key is 256 bit
Compression: NONE
Expansion: NONE
No ALPN negotiated
Post-Handshake New Session Ticket arrived:
SSL-Session:
Protocol : TLSv1.3
Cipher : TLS_AES_128_GCM_SHA256
Session-ID: 33283B3B4EA4A2D77C5C72FDFF0C17F1FBF33CD56CD085464455FFB9B83E61BC
Session-ID-ctx:
Resumption PSK: 85EBFE53C3D921F5EC403979E765F4BA3E19731056EA6DA515FE59CB7B898EA2
PSK identity: None
PSK identity hint: None
SRP username: None
TLS session ticket lifetime hint: 604800 (seconds)
TLS session ticket:
0000 - 90 e5 40 33 25 b8 0f ec-5f 1b ff ac df 7f d5 d6 ..@3%..._.......
0010 - 07 53 9d 62 79 74 a2 ad-94 1c cf 23 8f 78 4f 93 .S.byt.....#.xO.
0020 - 88 2f 20 42 30 d4 d9 9a-ef df 5f e6 f2 e6 3f 42 ./ B0....._...?B
0030 - 19 83 bc d2 5c 71 13 c7-50 03 c6 80 d4 d5 e1 b6 ....\q..P.......
0040 - 70 1b 4e 3a f6 96 50 bc-5b ff c7 f8 ae 3c eb 4c p.N:..P.[....<.L
0050 - e9 07 87 00 88 ac c0 d8-d8 9b 99 3b 4b 49 16 6f ...........;KI.o
0060 - fd b7 a1 eb 36 d2 0a da-e7 8c 19 54 9d c2 5f 97 ....6......T.._.
0070 - aa .
Start Time: 1659554217
Timeout : 7200 (sec)
Extended master secret: no
Max Early Data: 0
read R BLOCK
