How can I apply to reverse-proxy setting on Caddyfile?
i deployed front and back on the railway
now, backend(React App) is correctly called. however, frontend(https://oieho.xyz) isn’t correctly called
it hasn’t error message on the console but not working correctly
3. Caddy version: CADDY_VERSION = ‘2.7.4’
I installed caddy on the railway.app, it contains Caddyfile on the react root folder.
railway cloud.
I added Caddyfile to below scripts
oieho.xyz { route { reverse_proxy /api/* https://portfolio-v2-backend-production.up.railway.app try_files {path} /index.html file_server } }
now, To show presently deployed project status, visit http://oieho.xyz
if you refer to my dns settings. just click below it.
thank you for your interesting. so I prey for reply.
