I am trying to run 2 servers:
Server 1 (acme_server): ACME Server, listens on localhost:14431
Server 2 (external_interfaces): generic Server (in this example answers “Hello World”), listens on 0.0.0.0 :443 and :80
Requests are sent via curl -vkL
On Server 1 I use a host matcher that results in unwanted behaviour:
HTTP requests from localhost directed at Server 2 get rerouted to Server 1, although the port does not match with the port from Server 1. Sending the same request via HTTPS results in the correct answer from Server 2. Also HTTP requests that are not coming from localhost are accepted.
I would expect that requests to Server 1 should match the Port 14431 to be accepted. But apparently the host matcher is more powerful than the “listen” directive. Is this behavior wanted?
When I remove the host matcher on Server 1 the server only accepts HTTP requests. Server 2 on the other hand now accepts both HTTP and HTTPS.
This is probably because a host matcher is needed to enable HTTPS
Automatic HTTPS — Caddy Documentation (caddyserver.com)
My goal is that HTTP and HTTPS requests from localhost to Server 2 result in the correct reply and also that Server 1 accepts HTTPS requests.
With host matcher:
HTTP Request to Server 1 :
-> % curl -v http://localhost:14431/acme/root_ca/directory -k -L
* Trying 127.0.0.1:14431...
* TCP_NODELAY set
* Connected to localhost (127.0.0.1) port 14431 (#0)
> GET /acme/root_ca/directory HTTP/1.1
> Host: localhost:14431
> User-Agent: curl/7.68.0
* HTTP 1.0, assume close after body
< HTTP/1.0 400 Bad Request
Client sent an HTTP request to an HTTPS server.
* Closing connection 0
HTTPS Request to Server 1 :
-> % curl -v https://localhost:14431/acme/root_ca/directory -k -L
* TCP_NODELAY set
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
* subject: [NONE]
* start date: Jul 5 13:22:37 2023 GMT
* expire date: Jul 6 01:22:37 2023 GMT
* issuer: CN=Caddy Local Authority - ECC Intermediate
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x556589aa5300)
> GET /acme/root_ca/directory HTTP/2
> user-agent: curl/7.68.0
> accept: */*
< HTTP/2 200
< alt-svc: h3=":14431"; ma=2592000
< content-type: application/json
< server: Caddy
< content-length: 312
< date: Wed, 05 Jul 2023 14:12:08 GMT
{"newNonce":"https://localhost:14431/acme/root_ca/new-nonce","newAccount":"https://localhost:14431/acme/root_ca/new-account","newOrder":"https://localhost:14431/acme/root_ca/new-order","revokeCert":"https://localhost:14431/acme/root_ca/revoke-cert","keyChange":"https://localhost:14431/acme/root_ca/key-change"}
HTTP Request to Server 2 :
-> % curl -v http://localhost/test -k -L
* Trying 127.0.0.1:80...
* TCP_NODELAY set
* Connected to localhost (127.0.0.1) port 80 (#0)
> GET /test HTTP/1.1
> Host: localhost
< Alt-Svc: h3=":443"; ma=2592000
< Connection: close
< Location: https://localhost:14431/test
< Server: Caddy
< Date: Wed, 05 Jul 2023 14:12:13 GMT
< Content-Length: 0
* Clear auth, redirects to port from 80 to 14431Issue another request to this URL: 'https://localhost:14431/test'
* TCP_NODELAY set
* Connected to localhost (127.0.0.1) port 14431 (#1)
* ALPN, offering h2
* subject: [NONE]
* Using Stream ID: 1 (easy handle 0x5601e49bd300)
> GET /test HTTP/2
> accept: */*
< HTTP/2 200
< server: Caddy
< content-length: 0
< date: Wed, 05 Jul 2023 14:12:13 GMT
* Connection #1 to host localhost left intact
HTTPS Request to Server 2 :
-> % curl -v https://localhost/test -k -L
* Trying 127.0.0.1:443...
* TCP_NODELAY set
* Connected to localhost (127.0.0.1) port 443 (#0)
* ALPN, offering h2
* subject: [NONE]
* Using Stream ID: 1 (easy handle 0x564e80d37300)
> GET /test HTTP/2
> Host: localhost
> accept: */*
< HTTP/2 200
< content-type: text/plain; charset=utf-8
< server: Caddy
< content-length: 12
< date: Wed, 05 Jul 2023 14:12:11 GMT
Hello, world%
Without host matcher:
* TCP_NODELAY set
< HTTP/1.1 200 OK
< Content-Type: application/json
< Server: Caddy
< Date: Wed, 05 Jul 2023 14:11:06 GMT
< Content-Length: 312
* TCP_NODELAY set
* ALPN, offering h2
* error:1408F10B:SSL routines:ssl3_get_record:wrong version number
curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number
* TCP_NODELAY set
> GET /test HTTP/1.1
> Host: localhost
< HTTP/1.1 200 OK
< Server: Caddy
< Date: Wed, 05 Jul 2023 14:11:22 GMT
< Content-Length: 12
Hello, world%
* TCP_NODELAY set
* ALPN, offering h2
* subject: [NONE]
* start date: Jul 5 11:52:01 2023 GMT
* expire date: Jul 5 23:52:01 2023 GMT
* issuer: CN=Caddy Root CA - ECC Intermediate
* Using Stream ID: 1 (easy handle 0x5564bcb10300)
> GET /test HTTP/2
> Host: localhost
> accept: */*
< HTTP/2 200
< server: Caddy
< date: Wed, 05 Jul 2023 14:11:18 GMT
Hello, world%
WSL
sudo caddy run --config local_test_caddy_server_localhost_matcher.json
"apps": {
"http": {
"servers": {
"acme_server": {
"listen": [
"127.0.0.1:14431"
"routes": [
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"ca": "root_ca",
"handler": "acme_server"
"match": [
"host": [
"localhost"
"external-interfaces": {
"automatic_https": {
"disable_redirects": true
"listen": [
"0.0.0.0:80",
"0.0.0.0:443"
"routes": [
"handle": [
"routes": [
"handle": [
"body": "Hello, world",
"handler": "static_response",
"status_code": 200
"match": [
"path": [
"/test"
"strict_sni_host": false,
"tls_connection_policies": [
"cipher_suites": [
"TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256",
"TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256",
"TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384",
"TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384",
"TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256",
"TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256"
"protocol_max": "tls1.3",
"protocol_min": "tls1.2"
"pki": {
"certificate_authorities": {
"root_ca": {
"name": "Caddy Root CA"
"tls": {
"automation": {
"on_demand": {
"rate_limit": {
"burst": 5,
"interval": "1m"
"policies": [
"issuers": [
"ca": "root_ca",
"module": "internal"
"key_type": "rsa2048",
"on_demand": true
