HomePage 404 problem
1. Caddy version:
v2.6.2
use service file
ubuntu 20 amd64
Type=simple
ExecStart=/usr/bin/caddy run --config /etc/caddy/Caddyfile
  auto_https disable_redirects
(base_configuration) {
    root * .
    file_server {
        index index.html
    handle_errors {
            rewrite * /index.html
    import base_configuration
:443 {
    tls /etc/caddy/cert/server.crt /etc/caddy/cert/server.key
I use it on my laptop. I work with no problem. But, when I use it on my VPS. It can not find my index.html. It return me HTTP 404.
Feb 03 12:45:27 shywind1.server.com caddy[65547]: {"level":"error","ts":1675424727.1523185,"logger":"http.log.error","msg":"error handling handler error","request":{"remote_ip":"122.116.52.140","remote_port":"51092","proto":"HTTP/1.1","method":"GET","host":"103.61.139.106","uri":"/index.html","headers":{"Accept-Language":["zh,zh-TW;q=0.9,zh-CN;q=0.8,en;q=0.7,en-US;q=0.6,ru;q=0.5"],"Cookie":[],"Connection":["keep-alive"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Accept-Encoding":["gzip, deflate"],"Cache-Control":["max-age=0"]}},"duration":0.001510796,"error":"{id=y14qsx062} fileserver.(*FileServer).notFound (staticfiles.go:579): HTTP 404","first_error":{"msg":"{id=hpscjfjbm} fileserver.(*FileServer).notFound (staticfiles.go:579): HTTP 404","status":404,"err_id":"hpscjfjbm","err_trace":"fileserver.(*FileServer).notFound (staticfiles.go:579)"}}
When I use command line to execute it. That works normally.
This means “the current working directory of Caddy”.
When you’re running Caddy as a service, this path will probably be the HOME of the user under which Caddy is running.
You should probably use an absolute path instead, to make sure there’s no ambiguity.
If that still doesn’t work, enable the debug global option and look again at your logs. It might reveal more detail about the problem.
