hendry
(Kai Hendry)
1
Hi guys,
Following on from twitter, I’m planning to host a Voidlinux distribution mirror behind Caddy. I noticed with the rsync that I run, tmp files show.
Googling I found an old bug I created https://github.com/mholt/caddy/issues/458#issuecomment-189753794 but the solution results in 2018/09/30 13:49:42 Caddyfile:7 - Error during parsing: Wrong argument count or unexpected line ending after 'status'
888.dabase.com:2015 {
tls off
root /mnt/mirror
browse
rewrite {
if {file} starts_with .
status 404
So any tips here please? Thank you in advance!
p.s. i noticed that dir listing are quite slow. Any tips here for caching or boosting browse performance?
Whitestrake
(Matthew Fay)
2
Hi @hendry,
I don’t know if that fix ever worked, because I don’t recall a time when rewrite
ever supported a status
subdirective.
You’ll need to use status
outside of that directive, rewriting to something specific that you can then set the status on, like so:
rewrite {
to /status_404_dotfile
status 404 /status_404_dotfile
In the above, /status_404_dotfile
can be replaced with any sufficiently unique URL that wont clash with a real request.
https://caddyserver.com/docs/rewrite
https://caddyserver.com/docs/status
matt
(Matt Holt)
3
It did for a few versions - a short time - before we decided to move it outside to its own directive. It’s better this way for sure.
magikstm
(Magikstm)
4
system
(system)
Closed
5
