Is that the certificate that is passed to curl with --cert
curl --cert ~/client.crt
I still can’t authenticate. This is the new Caddyfile:
vfm1-ub20-sdev-11.int.fmorales.net {
reverse_proxy https://127.0.0.1:8443 {
tls_trusted_ca_certs /var/snap/lxd/common/lxd/server.crt
header_up X-Client-Cert {tls_client_certificate_der_base64}
I have tried with X-Client-Cert
and Client-Cert
. Is there another header I can try? I have tried to find out how LXD works with this with no luck.
This is the curl commend with full log (using jq to better display):
* TCP_NODELAY set
* Connected to vfm1-ub20-sdev-11.int.fmorales.net (192.168.1.229) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [15 bytes data]
{ [3806 bytes data]
{ [79 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
* subject: CN=vfm1-ub20-sdev-11.int.fmorales.net
* start date: Jun 26 18:00:55 2023 GMT
* expire date: Sep 24 18:00:54 2023 GMT
* subjectAltName: host "vfm1-ub20-sdev-11.int.fmorales.net" matched cert's "vfm1-ub20-sdev-11.int.fmorales.net"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
} [5 bytes data]
* Using Stream ID: 1 (easy handle 0x55d4588a2610)
} [5 bytes data]
> GET /1.0 HTTP/2
> Host: vfm1-ub20-sdev-11.int.fmorales.net
> user-agent: curl/7.68.0
> accept: */*
{ [5 bytes data]
{ [130 bytes data]
} [5 bytes data]
< HTTP/2 200
< content-security-policy: frame-ancestors 'self';
< content-type: application/json
< date: Wed, 28 Jun 2023 14:50:49 GMT
< permissions-policy: microphone=(), geolocation=(), camera=()
< referrer-policy: no-referrer-when-downgrade
< server: Caddy
< strict-transport-security: max-age=31536000;
< x-frame-options: SAMEORIGIN
{ [5 bytes data]
100 7548 0 7548 0 0 273k 0 --:--:-- --:--:-- --:--:-- 273k
* Connection #0 to host vfm1-ub20-sdev-11.int.fmorales.net left intact
"type": "sync",
"status": "Success",
"status_code": 200,
"operation": "",
"error_code": 0,
"error": "",
"metadata": {
"api_extensions": [
"storage_zfs_remove_snapshots",
"container_host_shutdown_timeout",
"container_stop_priority",
"container_syscall_filtering",
"auth_pki",
"container_last_used_at",
"etag",
"patch",
"usb_devices",
"https_allowed_credentials",
"image_compression_algorithm",
"directory_manipulation",
"container_cpu_time",
"storage_zfs_use_refquota",
"storage_lvm_mount_options",
"network",
"profile_usedby",
"container_push",
"container_exec_recording",
"certificate_update",
"container_exec_signal_handling",
"gpu_devices",
"container_image_properties",
"migration_progress",
"id_map",
"network_firewall_filtering",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_dhcp_expiry",
"storage_lvm_vg_rename",
"storage_lvm_thinpool_rename",
"network_vlan",
"image_create_aliases",
"container_stateless_copy",
"container_only_migration",
"storage_zfs_clone_copy",
"unix_device_rename",
"storage_lvm_use_thinpool",
"storage_rsync_bwlimit",
"network_vxlan_interface",
"storage_btrfs_mount_options",
"entity_description",
"image_force_refresh",
"storage_lvm_lv_resizing",
"id_map_base",
"file_symlinks",
"container_push_target",
"network_vlan_physical",
"storage_images_delete",
"container_edit_metadata",
"container_snapshot_stateful_migration",
"storage_driver_ceph",
"storage_ceph_user_name",
"resource_limits",
"storage_volatile_initial_source",
"storage_ceph_force_osd_reuse",
"storage_block_filesystem_btrfs",
"resources",
"kernel_limits",
"storage_api_volume_rename",
"macaroon_authentication",
"network_sriov",
"console",
"restrict_devlxd",
"migration_pre_copy",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"network_dhcp_gateway",
"file_get_symlink",
"network_leases",
"unix_device_hotplug",
"storage_api_local_volume_handling",
"operation_description",
"clustering",
"event_lifecycle",
"storage_api_remote_volume_handling",
"nvidia_runtime",
"container_mount_propagation",
"container_backup",
"devlxd_images",
"container_local_cross_pool_handling",
"proxy_unix",
"proxy_udp",
"clustering_join",
"proxy_tcp_udp_multi_port_handling",
"network_state",
"proxy_unix_dac_properties",
"container_protection_delete",
"unix_priv_drop",
"pprof_http",
"proxy_haproxy_protocol",
"network_hwaddr",
"proxy_nat",
"network_nat_order",
"container_full",
"candid_authentication",
"backup_compression",
"candid_config",
"nvidia_runtime_config",
"storage_api_volume_snapshots",
"storage_unmapped",
"projects",
"candid_config_key",
"network_vxlan_ttl",
"container_incremental_copy",
"usb_optional_vendorid",
"snapshot_scheduling",
"snapshot_schedule_aliases",
"container_copy_project",
"clustering_server_address",
"clustering_image_replication",
"container_protection_shift",
"snapshot_expiry",
"container_backup_override_pool",
"snapshot_expiry_creation",
"network_leases_location",
"resources_cpu_socket",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"storage_api_remote_volume_snapshots",
"network_nat_address",
"container_nic_routes",
"rbac",
"cluster_internal_copy",
"seccomp_notify",
"lxc_features",
"container_nic_ipvlan",
"network_vlan_sriov",
"storage_cephfs",
"container_nic_ipfilter",
"resources_v2",
"container_exec_user_group_cwd",
"container_syscall_intercept",
"container_disk_shift",
"storage_shifted",
"resources_infiniband",
"daemon_storage",
"instances",
"image_types",
"resources_disk_sata",
"clustering_roles",
"images_expiry",
"resources_network_firmware",
"backup_compression_algorithm",
"ceph_data_pool_name",
"container_syscall_intercept_mount",
"compression_squashfs",
"container_raw_mount",
"container_nic_routed",
"container_syscall_intercept_mount_fuse",
"container_disk_ceph",
"virtual-machines",
"image_profiles",
"clustering_architecture",
"resources_disk_id",
"storage_lvm_stripes",
"vm_boot_priority",
"unix_hotplug_devices",
"api_filtering",
"instance_nic_network",
"clustering_sizing",
"firewall_driver",
"projects_limits",
"container_syscall_intercept_hugetlbfs",
"limits_hugepages",
"container_nic_routed_gateway",
"projects_restrictions",
"custom_volume_snapshot_expiry",
"volume_snapshot_scheduling",
"trust_ca_certificates",
"snapshot_disk_usage",
"clustering_edit_roles",
"container_nic_routed_host_address",
"container_nic_ipvlan_gateway",
"resources_usb_pci",
"resources_cpu_threads_numa",
"resources_cpu_core_die",
"api_os",
"container_nic_routed_host_table",
"container_nic_ipvlan_host_table",
"container_nic_ipvlan_mode",
"resources_system",
"images_push_relay",
"network_dns_search",
"container_nic_routed_limits",
"instance_nic_bridged_vlan",
"network_state_bond_bridge",
"usedby_consistency",
"custom_block_volumes",
"clustering_failure_domains",
"resources_gpu_mdev",
"console_vga_type",
"projects_limits_disk",
"network_type_macvlan",
"network_type_sriov",
"container_syscall_intercept_bpf_devices",
"network_type_ovn",
"projects_networks",
"projects_networks_restricted_uplinks",
"custom_volume_backup",
"backup_override_name",
"storage_rsync_compression",
"network_type_physical",
"network_ovn_external_subnets",
"network_ovn_nat",
"network_ovn_external_routes_remove",
"tpm_device_type",
"storage_zfs_clone_copy_rebase",
"gpu_mdev",
"resources_pci_iommu",
"resources_network_usb",
"resources_disk_address",
"network_physical_ovn_ingress_mode",
"network_ovn_dhcp",
"network_physical_routes_anycast",
"projects_limits_instances",
"network_state_vlan",
"instance_nic_bridged_port_isolation",
"instance_bulk_state_change",
"network_gvrp",
"instance_pool_move",
"gpu_sriov",
"pci_device_type",
"storage_volume_state",
"network_acl",
"migration_stateful",
"disk_state_quota",
"storage_ceph_features",
"projects_compression",
"projects_images_remote_cache_expiry",
"certificate_project",
"network_ovn_acl",
"projects_images_auto_update",
"projects_restricted_cluster_target",
"images_default_architecture",
"network_ovn_acl_defaults",
"gpu_mig",
"project_usage",
"network_bridge_acl",
"warnings",
"projects_restricted_backups_and_snapshots",
"clustering_join_token",
"clustering_description",
"server_trusted_proxy",
"clustering_update_cert",
"storage_api_project",
"server_instance_driver_operational",
"server_supported_storage_drivers",
"event_lifecycle_requestor_address",
"resources_gpu_usb",
"clustering_evacuation",
"network_ovn_nat_address",
"network_bgp",
"network_forward",
"custom_volume_refresh",
"network_counters_errors_dropped",
"metrics",
"image_source_project",
"clustering_config",
"network_peer",
"linux_sysctl",
"network_dns",
"ovn_nic_acceleration",
"certificate_self_renewal",
"instance_project_move",
"storage_volume_project_move",
"cloud_init",
"network_dns_nat",
"database_leader",
"instance_all_projects",
"clustering_groups",
"ceph_rbd_du",
"instance_get_full",
"qemu_metrics",
"gpu_mig_uuid",
"event_project",
"clustering_evacuation_live",
"instance_allow_inconsistent_copy",
"network_state_ovn",
"storage_volume_api_filtering",
"image_restrictions",
"storage_zfs_export",
"network_dns_records",
"storage_zfs_reserve_space",
"network_acl_log",
"storage_zfs_blocksize",
"metrics_cpu_seconds",
"instance_snapshot_never",
"certificate_token",
"instance_nic_routed_neighbor_probe",
"event_hub",
"agent_nic_config",
"projects_restricted_intercept",
"metrics_authentication",
"images_target_project",
"cluster_migration_inconsistent_copy",
"cluster_ovn_chassis",
"container_syscall_intercept_sched_setscheduler",
"storage_lvm_thinpool_metadata_size",
"storage_volume_state_total",
"instance_file_head",
"resources_pci_vpd",
"qemu_raw_conf",
"storage_cephfs_fscache",
"vsock_api",
"storage_volumes_all_projects",
"projects_networks_restricted_access",
"cluster_join_token_expiry",
"remote_token_expiry",
"init_preseed",
"cpu_hotplug"
"api_status": "stable",
"api_version": "1.0",
"auth": "untrusted",
"public": false,
"auth_methods": [
"tls"
Thank you.
