2.3.0
Caddyfile is used
OS X
AWS Linux 2 AMI
Not using Docker
n/a
appsite.local localhost {
reverse_proxy 127.0.0.1:8000
applink.local {
redir https://appsite.local/app?token={uri} permanent
I am trying to redirect clients coming in to one domain (similar to a URL shortener) to a different domain.
the pattern coming in is
applink.local/<token here>
the pattern coming out (redirect) I want is:
appsite.local/app?token=<token here>
at which I am failing miserably.
I have tried
uri strip_prefix /
but this doesn’t seem to remove the leading /
