Caddy 2.2.1
Attempting to run Caddy as a web server to replace Nginx
Windows 10
.\caddy start
or
.\caddy run
N/A?
localhost {
root * C:/nginx/www/organizr/html
php_fastcgi * 127.0.0.1:9000
rewrite /api/v2/* /api/v2/index.php?{query}
I’m attempting to replace Nginx with Caddy because of the simplicity and the HTTPS automation. I believe I don’t need to reverse proxy as these services (Organizr, Sonarr, Radarr) aren’t facing the public internet, they are only accessed locally and over VPN. I’m able to serve Organizr with Caddy and my issue comes from the services Organizr points to and attempting to connect from a different machine.
Error when using a laptop to connect to server: SSL_ERROR_INTERNAL_ERROR_ALERT
Error when loading https://localhost/ in a web browser: Blocked loading mixed active content “http://192.168.4.3:8096/”
From what I understand, the second error can easily be solved by getting all of my services on HTTPS. Can I do this with Caddy’s automatic HTTPS?
I’ve attempted to create self-signed certs but I have discovered I have no idea what I’m doing.
