hi, help plz
rewrite /app/index.html {
to /{1}
i have install webogram at abc.site.com/app/index.html#/login
but i want to open at /
hi, help plz
to /{1}
Hi @simplemice,
Your substitution has a capture group, but you don’t have a regex capturing anything, so the instance of {1}
is always empty for any given request.
I’m not sure exactly what you mean by “i want to open at /”, I’m sorry. Could you be more specific?
You can simply rewrite the exact URIs:
rewrite /app/index.html#/login /
@Whitestrake i try it, it not working for me, because #/login
is autoinsert in url on opening abc.site.com/app/index.html
What’s your full Caddyfile?
abc.site.com {
log /var/log/caddy/abc.log
errors /var/log/caddy/abc_errors.log
dns cloudflare
proxy / 172.17.0.5:8000 {
header_upstream Host {host}
header_upstream X-Forwarded-For {remote}
fail_timeout 0s
header_upstream X-Forwarded-Ssl on
to /{1}
There’s nothing in your Caddyfile putting the #/login
there, so it’s probably your upstream server doing that. You’ll probably need to configure it not to.
@Whitestrake ohh… tnx for u help… on upstream work docker image with webogram and caddy is an proxy for it uncomfortable open full url */app/index.html
