pavlik
(Pavel Pavlenko)
#1
Hi! I try to convert NGINX config to Caddy & need help with proxy with path rewrite
This is nginx.conf
server {
listen 80;
server_name mysite.ru;
ssl off;
client_max_body_size 64m;
proxy_connect_timeout 600;
proxy_send_timeout 600;
proxy_read_timeout 600;
send_timeout 600;
location / {
proxy_pass http://localhost:81; # existing instance
location /service/ucsregister {
rewrite ^/service/ucsregister(.*) /ucs/register$1 break;
proxy_pass http://localhost:1235;
location /service/ucscallback {
rewrite ^/service/ucscallback(.*) /ucs/callback$1 break;
This is my try of Caddyfile variant. What solution is right?
mysite.ru {
proxy / localhost:81 # CRM on apache
rewrite /service/ucsregister {
r (.*)
to /ucs/register{1}
proxy /service/ucsregister http://localhost:1235
rewrite /service/ucscallback {
r (.*)
to /ucs/callback{1}
proxy /service/ucscallback http://localhost:1235
Whitestrake
(Matthew Fay)
#2
Looks good at a glance. You may wish to add the transparent
preset for your proxy
directive.
Are you having any problems?
pavlik
(Pavel Pavlenko)
#3
What param need to add to transparent
This is full finished config
mysite.ru {
r (.*)
to /ucs/register{1}
proxy /ucs/register localhost:1235
r (.*)
to /ucs/callback{1}
proxy /ucs/callback localhost:1235
rewrite /service/ucspreview {
r (.*)
to /ucs/preview{1}
proxy /ucs/ucspreview localhost:1235
rewrite /service/mandarincheck {
r (.*)
to /mandarin/check{1}
proxy /mandarin/check localhost:1235
rewrite /service/mandarinredirect {
r (.*)
to /mandarin/redirect{1}
proxy /mandarin/redirect localhost:1235
rewrite /service/scoristaview {
r (.*)
to /scorista/view/solution{1}
proxy /scorista/view/solution localhost:6660
proxy /static localhost:1235
proxy /scoring/static localhost:6660
Have a look at the presets in the proxy docs for an explanation of how they work and what they do.
system
(system)
closed
#5
