Hello friends, I humbly ask for your assistance as I have been driving myself in circles and can’t Sherlock the solution to get my subdomain to not 404. I feel that it’s a matter of a volume mis-mount between docker-compose and caddy.
[gregieandme.com] → Works fine for serving static html
[tools.gregieandme.com] → Laravel/Php site / can’t generate a certificate and returns a 404.
I believe my issue here is one of the Caddyfile php_fastcgi not matching its root to the docker-compose one, but being a novice I am not sure if getting warm. I’m trying to ensure the roots are pointed to the public laravel folder.
DNS A records are set up correctly.
Files are present in their correct directories
docker logs caddy
{"level":"error","ts":1748268123.4745073,"msg":"challenge failed","identifier":"tools.gregieandme.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"147.79.78.19: Invalid response from http://tools.gregieandme.com/.well-known/acme-challenge/eNA1aoFDW_xTGuOvgN1YfcdkVtChRAqicQiY7OJdvKI: 404","instance":"","subproblems":null},"stacktrace":"github.com/mholt/acmez/v3.(*Client).pollAuthorization\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:557\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:378\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
{"level":"error","ts":1748268123.474629,"msg":"validating authorization","identifier":"tools.gregieandme.com","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"147.79.78.19: Invalid response from http://tools.gregieandme.com/.well-known/acme-challenge/eNA1aoFDW_xTGuOvgN1YfcdkVtChRAqicQiY7OJdvKI: 404","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/201932904/24908611294","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.23.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.0/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.23.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.23.0/async.go:73"}
Caddy is running via docker compose and works fine on static html sites.
VPS running Ubuntu
Docker version 28.1.1, build 4eba377
docker compose up
docker-compose.yml
image: caddy:latest
- ./sites/gregieandme/www:/srv/site1.com
- ./sites/gregieandme/tools:/srv/laravel-app1
- ./caddy_data:/data
- caddy_config:/config
depends_on:
- laravel1
- mysql1
laravel1:
image: php:8.3-fpm
container_name: laravel1-tools.gregieandme
working_dir: /var/www
- ./sites/gregieandme/tools:/var/www
depends_on:
- mysql1
mysql1:
image: mysql:8.0
container_name: mysql1-tools.gregieandme
MYSQL_ROOT_PASSWORD: ${MYSQL1_ROOT_PASSWORD}
MYSQL_DATABASE: ${MYSQL1_DATABASE}
MYSQL_USER: ${MYSQL1_USER}
MYSQL_PASSWORD: ${MYSQL1_PASSWORD}
- mysql1_data:/var/lib/mysql
Caddyfile
gregieandme.com, www.gregieandme.com {
root * /srv/site1.com
tools.gregieandme.com {
root * /srv/laravel-app1/public
php_fastcgi laravel1:9000 {
root /var/www/public
Curl response
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: curl - SSL CA Certificates
how to fix it, please visit the web page mentioned above.
Thank you in advance, I’m sure I’m doing something wrong here. I have a feeling the error is in my docker-compose.yml file
