1. Output of caddy version
Installed from official repo
Ubuntu 20.04 LTS
systemctl start caddy
caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2023-01-18 22:10:56 UTC; 11min ago
Main PID: 19290 (caddy)
Tasks: 7 (limit: 1066)
Memory: 8.1M
└─19290 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
my.domain
tls admin@my.domain
root * /var/www/html/
handle /path {
reverse_proxy 127.0.0.1:10020
Caddy spits Error when I reload it.
WARN Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 1}
Already tried caddy fmt
and replaced the output but its returning this error
WARN Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
