Help unable to connect
iam unable to connect to the https address.
iam trying to connect my jellfin via reverse proxy to the outside world.
i am using the ddns from my asus router. and the jellfin is installed as is not in docker or something like this..
also i opend port 80 and 443 at the router
caddy[4015]: {"level":"info","ts":1706449301.4439585,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
caddy[4015]: {"level":"warn","ts":1706449301.4444268,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
caddy[1586]: {"level":"info","ts":1706449301.4448192,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"43112","headers":{"Accept-Encoding":["gzip"],"Cache-Control":["must-revalidate"],"Content-Length":["321"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
caddy[1586]: {"level":"info","ts":1706449301.445058,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy[1586]: {"level":"info","ts":1706449301.4451141,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy[1586]: {"level":"info","ts":1706449301.445122,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy[1586]: {"level":"debug","ts":1706449301.4451373,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:8096"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
caddy[1586]: {"level":"info","ts":1706449301.4452348,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy[1586]: {"level":"debug","ts":1706449301.4452436,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
caddy[1586]: {"level":"info","ts":1706449301.4452472,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy[1586]: {"level":"debug","ts":1706449301.4452615,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
caddy[1586]: {"level":"info","ts":1706449301.4452648,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy[1586]: {"level":"info","ts":1706449301.4452672,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["jellyfin.odedreut80110.asuscomm.com"]}
caddy[1586]: {"level":"info","ts":1706449301.4453213,"logger":"http","msg":"servers shutting down with eternal grace period"}
caddy[1586]: {"level":"error","ts":1706449301.445354,"logger":"tls","msg":"job failed","error":"jellyfin.odedreut80110.asuscomm.com: obtaining certificate: unable to acquire lock 'issue_cert_jellyfin.odedreut80110.asuscomm.com': context canceled"}
caddy[1586]: {"level":"info","ts":1706449301.4454193,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
caddy[1586]: {"level":"info","ts":1706449301.4454405,"logger":"admin.api","msg":"load complete"}
caddy[1586]: {"level":"info","ts":1706449301.44552,"logger":"tls.obtain","msg":"acquiring lock","identifier":"jellyfin.odedreut80110.asuscomm.com"}
systemd[1]: Reloaded Caddy.
caddy[1586]: {"level":"info","ts":1706449301.4464986,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
systemd[1]: Stopping Caddy...
caddy[1586]: {"level":"info","ts":1706449329.1819098,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
caddy[1586]: {"level":"warn","ts":1706449329.1820827,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
caddy[1586]: {"level":"info","ts":1706449329.182174,"logger":"http","msg":"servers shutting down with eternal grace period"}
caddy[1586]: {"level":"error","ts":1706449329.18257,"logger":"tls","msg":"job failed","error":"jellyfin.odedreut80110.asuscomm.com: obtaining certificate: unable to acquire lock 'issue_cert_jellyfin.odedreut80110.asuscomm.com': context canceled"}
caddy[1586]: {"level":"info","ts":1706449329.1826153,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
caddy[1586]: {"level":"info","ts":1706449329.182643,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
systemd[1]: caddy.service: Deactivated successfully.
systemd[1]: Stopped Caddy.
systemd[1]: Starting Caddy...
caddy[4146]: caddy.HomeDir=/var/lib/caddy
caddy[4146]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
caddy[4146]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
caddy[4146]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
caddy[4146]: caddy.Version=v2.7.6 h1:w0NymbG2m9PcvKWsrXO6EEkY9Ru4FJK8uQbYcev1p3A=
caddy[4146]: runtime.GOOS=linux
caddy[4146]: runtime.GOARCH=amd64
caddy[4146]: runtime.Compiler=gc
caddy[4146]: runtime.NumCPU=12
caddy[4146]: runtime.GOMAXPROCS=12
caddy[4146]: runtime.Version=go1.21.5
caddy[4146]: os.Getwd=/
caddy[4146]: LANG=en_IL
caddy[4146]: LANGUAGE=en_IL:en
caddy[4146]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
caddy[4146]: NOTIFY_SOCKET=/run/systemd/notify
caddy[4146]: HOME=/var/lib/caddy
caddy[4146]: LOGNAME=caddy
caddy[4146]: USER=caddy
caddy[4146]: INVOCATION_ID=4715be060b314a2ea3454d7fed54cdad
caddy[4146]: JOURNAL_STREAM=8:47281
caddy[4146]: SYSTEMD_EXEC_PID=4146
caddy[4146]: {"level":"info","ts":1706449329.2810054,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
caddy[4146]: {"level":"warn","ts":1706449329.2816067,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
caddy[4146]: {"level":"info","ts":1706449329.2819114,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
caddy[4146]: {"level":"info","ts":1706449329.28197,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy[4146]: {"level":"info","ts":1706449329.2819774,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy[4146]: {"level":"debug","ts":1706449329.2819943,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:8096"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
caddy[4146]: {"level":"info","ts":1706449329.2820728,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0005dcb00"}
caddy[4146]: {"level":"info","ts":1706449329.2821786,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy[4146]: {"level":"debug","ts":1706449329.2822812,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
caddy[4146]: {"level":"info","ts":1706449329.282286,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy[4146]: {"level":"debug","ts":1706449329.282303,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
caddy[4146]: {"level":"info","ts":1706449329.282306,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy[4146]: {"level":"info","ts":1706449329.2823086,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["jellyfin.odedreut80110.asuscomm.com"]}
caddy[4146]: {"level":"info","ts":1706449329.2824168,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
caddy[4146]: {"level":"info","ts":1706449329.2824357,"msg":"serving initial configuration"}
systemd[1] : Started Caddy.
caddy[4146]: {"level":"info","ts":1706449329.2839026,"logger":"tls.obtain","msg":"acquiring lock","identifier":"jellyfin.odedreut80110.asuscomm.com"}
caddy[4146]: {"level":"warn","ts":1706449329.2859483,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"17b53d25-ce7f-4f7a-8659-2c7464631914","try_again":1706535729.285947,"try_again_in":86399.999999749}
caddy[4146]: {"level":"info","ts":1706449329.2859788,"logger":"tls","msg":"finished cleaning storage units"}
from https://caddyserver.com/docs/install under Ubuntu part :
sudo apt update
sudo apt install caddy
Ubuntu 22.04.3 LTS - Desktop in headless mode?
sudo systemctl status caddy
sudo systemctl reload caddy
sudo systemctl stop caddy
sudo systemctl restart caddy
sudo journalctl -u caddy --no-pager | less +G > ~/debug.log
no Docker/systemd/Kubernetes/make
i am using reguler systemctl
jellyfin.odedreut80110.asuscomm.com {
	reverse_proxy localhost:8096
I don’t think this domain resolves to an IP address with DNS. It seems like odedreut80110.asuscomm.com does though. Are you sure your DDNS supports subdomains?
