Hello,
I want to know how to remove the extension from the page at the end of the url of my website. for example: https://example.com/inscription.php > how to remove “.php” in my URL? i am using caddy v2.6.2 for debian 11 bullseye.
here is an example of my config from my caddyfile:
exemple.com:443 {
root * /var/www/dgx/exemple.com
encode gzip zstd
@static {
file
header @static Cache-Control max-age=5184000
Thanks for help !
