Can not get my Duckdns domain to work
ERR ts=1717858263.2264428 logger=tls.obtain msg=could not get certificate from issuer identifier=gharomv.duckdns.org issuer=acme-v02.api.letsencrypt.org-directory error=[gharomv.duckdns.org] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of "_acme-challenge.gharomv.duckdns.org": dial udp: lookup ns8.duckdns.org. on 127.0.0.11:53: no such host (order=https://acme-v02.api.letsencrypt.org/acme/order/1771004187/276568303427) (ca=https://acme-v02.api.letsencrypt.org/directory)
ERR ts=1717858277.4254181 logger=tls.obtain msg=could not get certificate from issuer identifier=gharomv.duckdns.org issuer=acme-v02.api.letsencrypt.org-directory error=[gharomv.duckdns.org] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of "_acme-challenge.gharomv.duckdns.org": read udp 192.168.1.197:42070->3.97.51.116:53: read: connection refused (order=https://acme-v02.api.letsencrypt.org/acme/order/1771004187/276568387647) (ca=https://acme-v02.api.letsencrypt.org/directory)
ERR ts=1717858277.425532 logger=tls.obtain msg=will retry error=[gharomv.duckdns.org] Obtain: [gharomv.duckdns.org] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of "_acme-challenge.gharomv.duckdns.org": read udp 192.168.1.197:42070->3.97.51.116:53: read: connection refused (order=https://acme-v02.api.letsencrypt.org/acme/order/1771004187/276568387647) (ca=https://acme-v02.api.letsencrypt.org/directory) attempt=1 retrying_in=60 elapsed=44.416629652 max_duration=2592000
v2.8.4 (Docker Container) (in a separate Docker Macvlan)
Using the Docker container (in a separate Docker Macvlan) with the custom Caddy module for Duckdns
docker run -d \
--name unicad \
--restart unless-stopped \
--ip 192.168.1.197 \
--dns 8.8.8.8 \
--network="net" \
-p 80:80 \
-p 443:443 \
-v /drive1t/dockerconf/caddy/caddy:/usr/bin/caddy \
-v /drive1t/dockerconf/caddy/Caddyfile:/etc/caddy/Caddyfile:rw \
-v /drive1t/dockerconf/caddy/caddy-config:/config \
-v /drive1t/dockerconf/caddy/caddy-data:/data \
-e DOMAIN=gharomv.duckdns.org \
-e EMAIL=gnas5@gmail.com \
-e TOKEN=secret \
-e LOG_FILE=/data/access.log \
-e DUCKDNS_DOMAIN=https://gharomv.duckdns.org \
-e DUCKDNS_TOKEN=secret \
caddy:latest
acme_ca https://acme-v02.api.letsencrypt.org/directory
acme_dns duckdns secret
gharomv.duckdns.org:443 {
dns duckdns secret
resolvers 8.8.8.8
reverse_proxy 192.168.1.9:8096
