Hello,
I really need to see how to recreate this using caddy. I have a Docker Compose file with 5 containers BUT two of the containers expose web apps/api. I can ONLY expose 1 port publicly, this works in NGINX
worker_processes 1;
events {
worker_connections 1024;
http {
server {
listen 8080;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
location /result/ {
proxy_pass http://result:80/;
proxy_redirect off;
location / {
if ($http_referer ~* (/result) ) {
proxy_pass http://result:80;
break;
proxy_pass http://vote:80;
