I’m using Caddy to reverse proxy Vaultwarden and I’d like to make the /admin/
panel accessible only from local IPs. The Vaultwarden Wiki says to use this snippet and then import it. I’ve done so and it works as expected, but I was wondering if someone could help me rewrite the vaultwarden_admin_redir
in an OCD-satisfying way, so that the snippet, which pertains to Vaultwarden only, sits within its own block, instead of with the global directives.
Thank you!
(vaultwarden_admin_redir) {
@admin {
path /admin*
not remote_ip private_ranges
redir @admin /
*.mydomain.com {
## Vaultwarden
@vaultwarden host vault.mydomain.com
handle @vaultwarden {
import vaultwarden_admin_redir
# Enable HTTP Strict Transport Security (HSTS)
# Disable cross-site filter (XSS)
X-XSS-Protection "0"
# # Disallow the site to be rendered within a frame (clickjacking protection)
X-Frame-Options "SAMEORIGIN"
# Prevent search engines from indexing (optional)
X-Robots-Tag "noindex, nofollow"
# Disallow sniffing of X-Content-Type-Options
# Server name removing
-Server
# Remove X-Powered-By though this shouldn't be an issue, better opsec to remove
-X-Powered-By
# Remove Last-Modified because etag is the same and is as effective
-Last-Modified
route {
crowdsec
reverse_proxy http://vaultwarden {
No error messages.
Docker-compose, built from sources with Porkbun DNS
FROM caddy:builder-alpine AS builder
RUN xcaddy build \
--with github.com/caddy-dns/porkbun \
--with github.com/hslatman/caddy-crowdsec-bouncer/http \
--with github.com/hslatman/caddy-crowdsec-bouncer/crowdsec \
--with github.com/hslatman/caddy-crowdsec-bouncer/layer4
FROM caddy:latest
image: caddy-porkbun:latest
build: .
security_opt:
- label:disable
- "443:443/udp"
- ./config:/etc/caddy
- ./logs:/logs
cap_add:
- NET_ADMIN
- valinor
valinor:
external: true
