- I would like to optimize/refactor this config file to make it more dynamic and modular (less repetitive).
- I want the reverse_proxy to run only if a channel is matched as currently it will run always when the route matches.
v2.10.0
(common_headers) {
header_up -Via
:8080 {
header -Via
# Group 1 Channels
route /1/* {
@channel1_root path_regexp ^/1/1/$
rewrite @channel1_root /FirstCh/hls/video.m3u8
@channel1 path_regexp ^/1/1/(.*)$
rewrite @channel1 /FirstCh/hls/{re.2}
@channel2_root path_regexp ^/1/2/$
rewrite @channel2_root /SecondCh/hls/video.m3u8
@channel2 path_regexp ^/1/2/(.*)$
rewrite @channel2 /SecondCh/hls/{re.2}
reverse_proxy http://127.0.0.1 {
import common_headers
# Group 2 Channels
route /2/* {
@channel1_root path_regexp ^/2/1/$
@channel1 path_regexp ^/2/1/(.*)$
@channel2_root path_regexp ^/2/2/$
@channel2 path_regexp ^/2/2/(.*)$
reverse_proxy http://another-host {
Your help is very much appreciated.
