Bitti09
(Bitti09)
#1
I need help converting this .htaccess file over to Caddy
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)$ index.php?$1 [L,QSA]
Nginx Version
index index.php;
try_files $uri $uri/ /index.php?$uri&$args;
aios
(Dave)
#2
Look for examples repo
example.com {
root ./public
fastcgi / 127.0.0.1:9000 php
rewrite {
to {path} {path}/ /index.php?{query}
is that can help you?
abiosoft
(Abiola Ibrahim)
#3
This is the direct translation of the nginx rewrite
rewrite {
{path} {path}/ /index.php?{uri} # or {uri_escaped} if required
Bitti09
(Bitti09)
#4
tried it on wotlab 4.x and new 5.0 beta
result:
all links are redirecting to /
system
(system)
closed
#5
