Caddy 2.4.5
start caddy with json config
Plain linux
Paste command here.
"logging": {
"logs": {
"default": {
"level": "debug"
"admin": {
"disabled": false,
"listen": "0.0.0.0:2019"
"apps": {
"http": {
"servers": {
"example": {
"listen": [
":2015"
"experimental_http3": true,
"routes": [
"handle": [
"handler": "reverse_proxy",
"transport": {
"protocol": "http",
"tls": {
"server_name": "httpbin.org"
"upstreams": [
"dial": "httpbin.org:443"
"headers": {
"request": {
"set": {
"Host": [
"{http.reverse_proxy.upstream.hostport}"
"health_checks": {
"active": {
"uri": "/aa",
"expect_status": 200,
"expect_body": "",
"interval": "10s",
"timeout": "5s",
"headers": {
"Host": [
"httpbin.org"
"example2": {
"listen": [
":2016"
"routes": [
"handle": [
"transport": {
"protocol": "http",
"tls": {
"upstreams": [
"headers": {
"request": {
"set": {
"Host": [
"health_checks": {
"active": {
"uri": "/",
"expect_body": "",
"interval": "10s",
"timeout": "5s",
"headers": {
"Host": [
"httpbin.org"
In the config you see that i have two servers, one on port 2015, the other 2016. both use the revers-proxy setting for httpbin.org
the first one does a health_check for the path “/aa” which is illegal on httpbin.org and returns a 404. if i only have this server, i get an error (for the healthcheck, which is ok). but as you can see, i have a second server on port 2016 and this has a health_check to “/” and this is ok.
the result is, that both servers are healthy although the first should be unhealthy.
