1. Caddy version (2.2.1
Debian 10 standard from the default systemd install
My complete Caddyfile or JSON config:
# domain name.
:8080
root * /var/www/red-service/www
# php_fastcgi localhost:9000
php_fastcgi unix//run/php/php7.3-fpm.sock
@test{
path_regexp test ^/test/(.+)/(.+)/([0-9]+)$
rewrite @test /test.php?m={http.regexp.test.1}&i={http.regexp.test.2}&mid={http.regexp.test.3}
It’s insisting that path regexes are invalid
Nov 26 13:57:49 tracker-01 caddy[27665]: run: adapting config using caddyfile: /etc/caddy/Caddyfile:30: unrecognized directive: path_regexp
Initially i tried other directives that didn’t work until i found that the rewrite directives changed a lot between v1 and 2. This is my latest attempt. Unless i’ve misread the docs this should work.
What am i doing wrong? Do i need to install something extra to have regex redirections?
