Thanks for the reply!
My DNS goes through DuckDNS and Cloudflare and has cname flattening, not sure if that would explain it? The website does load and works without templates enabled.
Here is the full log with debug enabled.
The last error message is key (022/07/05 21:51:27.416 ERROR) as this is the page that I tried to load that has templates included but doesn’t load and has a 500 error message.
caddy start
2022/07/05 21:49:40.894 e[34mINFOe[0m using adjacent Caddyfile
2022/07/05 21:49:40.897 e[33mWARNe[0m Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2022/07/05 21:49:40.902 e[34mINFOe[0m admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/07/05 21:49:40.902 e[34mINFOe[0m http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2022/07/05 21:49:40.903 e[34mINFOe[0m http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2022/07/05 21:49:40.902 e[34mINFOe[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc00045a310"}
2022/07/05 21:49:40.903 e[34mINFOe[0m tls cleaning storage unit {"description": "FileStorage:C:\\Users\\Administrator\\AppData\\Roaming\\Caddy"}
2022/07/05 21:49:40.903 e[35mDEBUGe[0m http starting server loop {"address": "[::]:443", "http3": false, "tls": true}
2022/07/05 21:49:40.904 e[35mDEBUGe[0m http starting server loop {"address": "[::]:80", "http3": false, "tls": false}
2022/07/05 21:49:40.904 e[34mINFOe[0m http enabling automatic TLS certificate management {"domains": ["ftl-computer-repairs.com.au", "www.ftl-computer.repairs.com.au"]}
2022/07/05 21:49:40.918 e[35mDEBUGe[0m tls loading managed certificate {"domain": "ftl-computer-repairs.com.au", "expiration": "2022/10/03 03:35:07.000", "issuer_key": "acme-v02.api.letsencrypt.org-directory", "storage": "FileStorage:C:\\Users\\Administrator\\AppData\\Roaming\\Caddy"}
2022/07/05 21:49:40.918 e[34mINFOe[0m tls finished cleaning storage units
2022/07/05 21:49:40.919 e[35mDEBUGe[0m tls.cache added certificate to cache {"subjects": ["ftl-computer-repairs.com.au"], "expiration": "2022/10/03 03:35:07.000", "managed": true, "issuer_key": "acme-v02.api.letsencrypt.org-directory", "hash": "567b14f7a2360c8ae7fc4562714898c9eedbc6a93427657e8a8ad778b37a83e5", "cache_size": 1, "cache_capacity": 10000}
2022/07/05 21:49:40.920 e[34mINFOe[0m autosaved config (load with --resume flag) {"file": "C:\\Users\\Administrator\\AppData\\Roaming\\Caddy\\autosave.json"}
2022/07/05 21:49:40.925 e[34mINFOe[0m serving initial configuration
2022/07/05 21:49:40.925 e[34mINFOe[0m tls.obtain acquiring lock {"identifier": "www.ftl-computer.repairs.com.au"}
Successfully started Caddy (pid=5016) - Caddy is running in the background
C:\Web Server\WebCaddyServer>2022/07/05 21:49:40.933 INFO tls.obtain lock acquired {"identifier": "www.ftl-computer.repairs.com.au"}
2022/07/05 21:49:40.933 DEBUG tls.obtain trying issuer 1/2 {"issuer": "acme-v02.api.letsencrypt.org-directory"}
2022/07/05 21:49:40.948 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["www.ftl-computer.repairs.com.au"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2022/07/05 21:49:40.949 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["www.ftl-computer.repairs.com.au"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2022/07/05 21:49:41.750 DEBUG tls.issuance.acme.acme_client http request {"method": "GET", "url": "https://acme-v02.api.letsencrypt.org/directory", "headers": {"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["658"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:40 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:42.015 DEBUG tls.issuance.acme.acme_client http request {"method": "HEAD", "url": "https://acme-v02.api.letsencrypt.org/acme/new-nonce", "headers": {"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Date":["Tue, 05 Jul 2022 21:49:40 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002Tl5-vTVX2-2uctGny8m2vkgkzjl36RSOTW8QSmY0E5w"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:42.320 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/new-order", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["356"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:41 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/617865126/104123329256"],"Replay-Nonce":["0001tKO1WeWMiC1iJREB1E3OvudBLI2WEry9ATZiElG6MgQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 201}
2022/07/05 21:49:42.582 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/127346163356", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["815"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:41 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002v6wDlADnyHdh6qCHKt-tmJIE8fEetodoGsjbUUC_tk4"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:42.588 DEBUG tls.issuance.acme.acme_client no solver configured {"challenge_type": "dns-01"}
2022/07/05 21:49:42.589 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "www.ftl-computer.repairs.com.au", "challenge_type": "http-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2022/07/05 21:49:42.845 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/127346163356/Ikau_w", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["187"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:41 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/authz-v3/127346163356>;rel=\"up\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/chall-v3/127346163356/Ikau_w"],"Replay-Nonce":["0002BHKKb14G2epofCkBkBqUxW_Y7GvFwEUIxgks5maFHGU"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:42.852 DEBUG tls.issuance.acme.acme_client challenge accepted {"identifier": "www.ftl-computer.repairs.com.au", "challenge_type": "http-01"}
2022/07/05 21:49:43.359 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/127346163356", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["815"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:42 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["00023qsG7bAIMdFKYTzFqjEEw_78ATyiGLrtMyLsyBWRI60"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:43.870 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/127346163356", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["792"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:42 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002oB6FjYjELBOXNAtbBwLkbMQEG5Q44mXplvSdFk05XBY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:43.873 ERROR tls.issuance.acme.acme_client challenge failed {"identifier": "www.ftl-computer.repairs.com.au", "challenge_type": "http-01", "problem": {"type": "urn:ietf:params:acme:error:dns", "title": "", "detail": "DNS problem: SERVFAIL looking up A for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning", "instance": "", "subproblems": []}}
2022/07/05 21:49:43.874 ERROR tls.issuance.acme.acme_client validating authorization {"identifier": "www.ftl-computer.repairs.com.au", "problem": {"type": "urn:ietf:params:acme:error:dns", "title": "", "detail": "DNS problem: SERVFAIL looking up A for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/617865126/104123329256", "attempt": 1, "max_attempts": 3}
2022/07/05 21:49:45.237 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/new-order", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["356"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:44 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/617865126/104123335956"],"Replay-Nonce":["0002fjxfMMqfsOb-56zh0gy_eXwJ366E40oW7jvMKEUPIlk"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 201}
2022/07/05 21:49:45.499 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/127346171976", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["815"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:44 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002ut_-RITw3Qb_YEJ8jCUGYWsvQUUj9Jod_pzVFSvwoIU"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:45.503 DEBUG tls.issuance.acme.acme_client no solver configured {"challenge_type": "dns-01"}
2022/07/05 21:49:45.504 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "www.ftl-computer.repairs.com.au", "challenge_type": "tls-alpn-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2022/07/05 21:49:45.506 DEBUG http.stdlib http: TLS handshake error from 127.0.0.1:51801: EOF
2022/07/05 21:49:45.760 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/127346171976/ZJGGBg", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["191"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:44 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/authz-v3/127346171976>;rel=\"up\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/chall-v3/127346171976/ZJGGBg"],"Replay-Nonce":["00010soeGjiUxE6hJnp62w2WtOJycmBIjrt_z9OTkD4sxf8"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:45.776 DEBUG tls.issuance.acme.acme_client challenge accepted {"identifier": "www.ftl-computer.repairs.com.au", "challenge_type": "tls-alpn-01"}
2022/07/05 21:49:46.288 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/127346171976", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["815"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:45 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0001NfYsZURPJsd0L16txde8pJVi_HEA-GlR0C5pLUBGUeA"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:46.798 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/127346171976", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Boulder-Requester":["617865126"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["934"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:45 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0002gIzR8l2Ez5Szrqpl1WdDWFVGFWJcQ337fTlk2gfwSP0"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2022/07/05 21:49:46.802 ERROR tls.issuance.acme.acme_client challenge failed {"identifier": "www.ftl-computer.repairs.com.au", "challenge_type": "tls-alpn-01", "problem": {"type": "urn:ietf:params:acme:error:dns", "title": "", "detail": "DNS problem: SERVFAIL looking up A for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning", "instance": "", "subproblems": []}}
2022/07/05 21:49:46.804 ERROR tls.issuance.acme.acme_client validating authorization {"identifier": "www.ftl-computer.repairs.com.au", "problem": {"type": "urn:ietf:params:acme:error:dns", "title": "", "detail": "DNS problem: SERVFAIL looking up A for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/617865126/104123335956", "attempt": 2, "max_attempts": 3}
2022/07/05 21:49:46.804 ERROR tls.obtain could not get certificate from issuer {"identifier": "www.ftl-computer.repairs.com.au", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "HTTP 400 urn:ietf:params:acme:error:dns - DNS problem: SERVFAIL looking up A for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for www.ftl-computer.repairs.com.au - the domain's nameservers may be malfunctioning"}
2022/07/05 21:49:46.805 DEBUG tls.obtain trying issuer 2/2 {"issuer": "acme.zerossl.com-v2-DV90"}
2022/07/05 21:49:46.806 WARN tls.issuance.zerossl missing email address for ZeroSSL; it is strongly recommended to set one for next time
2022/07/05 21:49:48.098 INFO tls.issuance.zerossl generated EAB credentials {"key_id": "RICibVlLD0M4yYm9Je_Ukg"}
2022/07/05 21:49:51.842 DEBUG tls.issuance.acme.acme_client http request {"method": "GET", "url": "https://acme.zerossl.com/v2/DV90", "headers": {"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["645"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:50 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:49:54.406 DEBUG tls.issuance.acme.acme_client http request {"method": "HEAD", "url": "https://acme.zerossl.com/v2/DV90/newNonce", "headers": {"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Type":["application/octet-stream"],"Date":["Tue, 05 Jul 2022 21:49:53 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["M9pWIRaPDnvwE6Qi0JcchcKsk86-tNAWmpWyCXUzxWQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:49:57.731 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/newAccount", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store","max-age=-1"],"Content-Length":["579"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:56 GMT"],"Location":["https://acme.zerossl.com/v2/DV90/account/RICibVlLD0M4yYm9Je_Ukg"],"Replay-Nonce":["SDhfc1CrNlFkuOR-uBAwdHkouj3drcsEIA5eKqM94XE"],"Server":["nginx"],"Status":[""],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 201}
2022/07/05 21:49:57.734 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["www.ftl-computer.repairs.com.au"], "ca": "https://acme.zerossl.com/v2/DV90", "account": ""}
2022/07/05 21:49:57.740 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["www.ftl-computer.repairs.com.au"], "ca": "https://acme.zerossl.com/v2/DV90", "account": ""}
2022/07/05 21:50:01.006 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/newOrder", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store","max-age=-1"],"Content-Length":["293"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:49:59 GMT"],"Location":["https://acme.zerossl.com/v2/DV90/order/lVk9b2_gnvDMmZXxPTaoJQ"],"Replay-Nonce":["kQc6VNftYDGgFLmzXaQxMzHvIoYtLl-F9QL3dKOijh4"],"Server":["nginx"],"Status":[""],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 201}
2022/07/05 21:50:04.290 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["461"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:03 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["6zlC5usJ5W9kQj8lM29Xe0gP-jS7IL3AEYJQubAbU1Y"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:50:04.300 DEBUG tls.issuance.acme.acme_client no solver configured {"challenge_type": "dns-01"}
2022/07/05 21:50:04.301 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "www.ftl-computer.repairs.com.au", "challenge_type": "http-01", "ca": "https://acme.zerossl.com/v2/DV90"}
2022/07/05 21:50:07.048 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/chall/zaq195fdNyua-yFM2F5Zrw", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["164"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:05 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\"","<https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ>;rel=\"up\""],"Replay-Nonce":["KcGH0bzzZl_VEyJyh5rsAaSy5ZOl7LiDXrCDJXNq9fA"],"Retry-After":["10"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:50:07.054 DEBUG tls.issuance.acme.acme_client challenge accepted {"identifier": "www.ftl-computer.repairs.com.au", "challenge_type": "http-01"}
2022/07/05 21:50:10.050 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["464"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:08 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["4NqWqIFDwiR7nsS5PWLplD65fF8svB_AGf3c-NkC_Hs"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:50:17.840 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["464"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:16 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["70snS2zPYo81SLsxsBXBm09Sp-DcgNi9s2ialAr66L4"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:50:25.624 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["464"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:24 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["9vD4pmuc7Dz6t0z47aV1sOCV7tL2yd6CY2msca40PGc"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:50:26.029 DEBUG tls.handshake choosing certificate {"identifier": "ftl-computer-repairs.com.au", "num_choices": 1}
2022/07/05 21:50:26.030 DEBUG tls.handshake default certificate selection results {"identifier": "ftl-computer-repairs.com.au", "subjects": ["ftl-computer-repairs.com.au"], "managed": true, "issuer_key": "acme-v02.api.letsencrypt.org-directory", "hash": "567b14f7a2360c8ae7fc4562714898c9eedbc6a93427657e8a8ad778b37a83e5"}
2022/07/05 21:50:26.030 DEBUG tls.handshake matched certificate in cache {"subjects": ["ftl-computer-repairs.com.au"], "managed": true, "expiration": "2022/10/03 03:35:07.000", "hash": "567b14f7a2360c8ae7fc4562714898c9eedbc6a93427657e8a8ad778b37a83e5"}
2022/07/05 21:50:26.248 DEBUG tls.handshake choosing certificate {"identifier": "ftl-computer-repairs.com.au", "num_choices": 1}
2022/07/05 21:50:26.248 DEBUG tls.handshake default certificate selection results {"identifier": "ftl-computer-repairs.com.au", "subjects": ["ftl-computer-repairs.com.au"], "managed": true, "issuer_key": "acme-v02.api.letsencrypt.org-directory", "hash": "567b14f7a2360c8ae7fc4562714898c9eedbc6a93427657e8a8ad778b37a83e5"}
2022/07/05 21:50:26.249 DEBUG tls.handshake matched certificate in cache {"subjects": ["ftl-computer-repairs.com.au"], "managed": true, "expiration": "2022/10/03 03:35:07.000", "hash": "567b14f7a2360c8ae7fc4562714898c9eedbc6a93427657e8a8ad778b37a83e5"}
2022/07/05 21:50:26.307 DEBUG http.handlers.file_server sanitized path join {"site_root": ".", "request_path": "/", "result": "."}
2022/07/05 21:50:26.308 DEBUG http.handlers.file_server located index file {"filename": "index.html"}
2022/07/05 21:50:26.308 DEBUG http.handlers.file_server opening file {"filename": "index.html"}
2022/07/05 21:50:26.343 INFO http.log.access handled request {"request": {"remote_ip": "139.59.173.249", "remote_port": "42740", "proto": "HTTP/1.1", "method": "GET", "host": "ftl-computer-repairs.com.au", "uri": "/", "headers": {"User-Agent": ["Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.uptimerobot.com/)"], "Accept-Language": ["en-US,en;q=0.8"], "Referer": ["https://ftl-computer-repairs.com.au"], "Accept-Encoding": [""], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"], "Accept-Charset": ["ISO-8859-1,UTF-8;q=0.7,*;q=0.7"], "Connection": ["close"], "Cache-Control": ["no-cache"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "ftl-computer-repairs.com.au"}}, "user_id": "", "duration": 0.0455169, "size": 28855, "status": 200, "resp_headers": {"Content-Type": ["text/html; charset=utf-8"], "Content-Length": ["28855"], "Server": ["Caddy"]}}
2022/07/05 21:50:26.358 DEBUG http.handlers.file_server sanitized path join {"site_root": ".", "request_path": "/", "result": "."}
2022/07/05 21:50:26.358 DEBUG http.handlers.file_server located index file {"filename": "index.html"}
2022/07/05 21:50:26.358 DEBUG http.handlers.file_server opening file {"filename": "index.html"}
2022/07/05 21:50:26.360 INFO http.log.access handled request {"request": {"remote_ip": "128.199.195.156", "remote_port": "59902", "proto": "HTTP/1.1", "method": "GET", "host": "ftl-computer-repairs.com.au", "uri": "/", "headers": {"User-Agent": ["Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.uptimerobot.com/)"], "Accept-Charset": ["ISO-8859-1,UTF-8;q=0.7,*;q=0.7"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"], "Accept-Language": ["en-US,en;q=0.8"], "Connection": ["close"], "Cache-Control": ["no-cache"], "Referer": ["https://ftl-computer-repairs.com.au"], "Accept-Encoding": [""]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "ftl-computer-repairs.com.au"}}, "user_id": "", "duration": 0.0139916, "size": 28855, "status": 200, "resp_headers": {"Content-Type": ["text/html; charset=utf-8"], "Content-Length": ["28855"], "Server": ["Caddy"]}}
2022/07/05 21:50:33.624 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["464"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:32 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["fCxATivRi5eLD4XyaG5ZnxaxJtliOhItty8eL3frOeQ"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:50:42.091 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["464"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:41 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["4dD-JVKnWTvxXIVaoWn5jEPQIZuwpP6W8kFYvmJq6eM"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:50:50.086 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["464"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:49 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["tY-hveVZ4K4WZExD8LxF3NOrN9wFqOqiPil9zB5uF5g"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:50:57.904 DEBUG tls.issuance.acme.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/f9z7CJy5AcqVSVvH2biZUQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.5.1 CertMagic acmez (windows; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=-1"],"Content-Length":["464"],"Content-Type":["application/json"],"Date":["Tue, 05 Jul 2022 21:50:56 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["UA9HuzmnPxGceNb6e_4JJZcUCDOH-5zx42iHonRD_qw"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15552000"]}, "status_code": 200}
2022/07/05 21:51:03.413 DEBUG tls.handshake no matching certificates and no custom selection logic {"identifier": "192.168.1.116"}
2022/07/05 21:51:03.414 DEBUG tls.handshake all external certificate managers yielded no certificates and no errors
