I’ve installed Caddy via Docker on Ubuntu Server to serve as an internal reverse proxy/HTTPS for other Docker containers on my machine.
I use OPNsense as a firewall and within it use Unbound to redirect local DNS queries for an internal domain (*.ubuntu.arpa) to the machine running Caddy.
Caddy currently operates as expected when I direct the domain to port 80 via http. However, when redirecting to 443, adding ‘tls internal’, and installing the root crt in Caddy’s data directory to the Windows machine I’m trying to access the domain from, the site continues to serve http and says not secure.
I’ve tried adding https / http in the relevant places within my Caddyfile to no avail. I’m not sure what else I might be missing to get HTTPS working?
I don’t understand. Are you not making your requests with https://?
Please make an example request with curl -v to show what behaviour you’re seeing.
This is fine, but FYI :443 is redundant, because Caddy is HTTPS by default. It will listen on both 80 and 443 when told to serve a domain, port 80 for the ACME HTTP challenge and HTTP->HTTPS redirects, and 443 for HTTPS.
C:\Windows\system32>curl -v https://linkding.ubuntu.arpa
* Trying 192.168.10.13:443...
* Connected to linkding.ubuntu.arpa (192.168.10.13) port 443 (#0)
* schannel: disabled automatic use of client certificate
* ALPN: offers http/1.1
* schannel: SEC_E_UNTRUSTED_ROOT (0x80090325) - The certificate chain was issued by an authority that is not trusted.
* Closing connection 0
curl: (60) schannel: SEC_E_UNTRUSTED_ROOT (0x80090325) - The certificate chain was issued by an authority that is not trusted.
how to fix it, please visit the web page mentioned above.
I’ve trusted Caddy’s certificate on the device I’m calling ‘curl’ from, so I’m not sure how else to trust the root certificate.
It seems the installation into your system trust store didn’t go quite like you thought, since the cert is still untrusted. Make sure to install your Caddy instance’s local root CA into the trust store.
