Hello,
I currently want to modify the request_body directive for the path :
/api/sends/*
this api is used to let the user uploading files in the application. I already by default setup a request body of 100KB.
I try to resolve this by using the matcher with the directive request_body but it is not working as expected (see error and Caddyfile).
Did i miss something ?
Regards,
BBA
"level": "error",
"ts": 1700575275.1537004,
"logger": "http.log.error",
"msg": "{id=jfxqaftd5} requestbody.errorWrapper.Read (requestbody.go:63): HTTP 413: http: request body too large",
"request": {
"remote_ip": "192.168.1.1",
"remote_port": "44120",
"client_ip": "192.168.1.1",
"proto": "HTTP/2.0",
"method": "POST",
"host": "vaultwarden.one4all.icu",
"uri": "/api/sends/25a594c0-df15-47a8-9829-2673ccca1c82/file/c07a1ec1003ce08be9da81e73792c794d30cc5e284183a30df47eadcc7cf65eb",
"headers": {
"Content-Length": [
"478029"
"Sec-Ch-Ua": [
"\"Brave\";v=\"119\", \"Chromium\";v=\"119\", \"Not?A_Brand\";v=\"24\""
"Sec-Ch-Ua-Mobile": [
"?0"
"User-Agent": [
"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
"Content-Type": [
"multipart/form-data; boundary=----WebKitFormBoundaryJsEDO73v7v7yDHzU"
"Sec-Gpc": [
"1"
"Origin": [
"https://vaultwarden.one4all.icu"
"Accept-Encoding": [
"gzip, deflate, br"
"Authorization": [],
"Sec-Ch-Ua-Platform": [
"\"Linux\""
"Accept-Language": [
"fr-FR,fr;q=0.5"
"Device-Type": [
"9"
"Bitwarden-Client-Version": [
"2023.10.0"
"Accept": [
"Sec-Fetch-Mode": [
"cors"
"Sec-Fetch-Dest": [
"empty"
"Bitwarden-Client-Name": [
"web"
"Sec-Fetch-Site": [
"same-origin"
"tls": {
"resumed": true,
"version": 772,
"cipher_suite": 4867,
"proto": "h2",
"server_name": "vaultwarden.one4all.icu"
"duration": 0.028404805,
"status": 500,
"err_id": "wlHcfBYQdfFZeGAY",
"err_trace": ""
Caddy is running as a container with docker.
OS architecture
Linux srvone4all 5.4.0-1097-raspi #109-Ubuntu SMP PREEMPT Wed Oct 11 16:15:36 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
NAME="Ubuntu"
VERSION="20.04.6 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.6 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
Docker version
Docker version 24.0.7, build afdd53b
Caddy is a service and it is build from a Dockerfile
docker compose up -d
c. Dockerfile:
FROM caddy:builder AS builder
RUN xcaddy build --with github.com/corazawaf/coraza-caddy@master
FROM caddy:alpine
RUN set -eux; \
apk add --no-cache libcap tzdata; \
setcap cap_net_bind_service=ep /usr/bin/caddy; \
addgroup -g 2023 -S www-caddy; \
adduser -u 2023 -D -S -G www-caddy www-caddy; \
chown -R www-caddy /data /var/log
USER www-caddy
WORKDIR /srv
CMD ["/usr/bin/caddy", "run", "--config", "/Caddyfile", "--adapter", "caddyfile"]
# coraza_waf first must be always included in your Caddyfile for Coraza module to work
order coraza_waf first
persist_config off
level INFO
servers {
timeouts {
# sets timeouts for various actions
idle 10s # timeout for idle connections
read_body 10s # timeout for reading request body
read_header 10s # timeout for reading request header
max_header_size 4KB # sets maximum header size for requests
# Default server block that will respond with a "Not found" message for all requests to port 443
:443 {
log
respond "Not found" 404
# Default server block that will respond with a "Not found" message for all requests to port 80
log
# Pour chacune de nos applications nous aurons des règles différentes à appliquer, si l'on souhaite traiter les faux positifs plus tard.
{$DOMAIN} {
log
coraza_waf {
# On charge les paramètres globaux de coraza.
include /ruleset/coraza.conf
# On charge les paramètres CRS specifique à notre site.
include /ruleset/vaultwarden/*.conf
# On charge toutes les règles CRS que le WAF utilisera.
include /ruleset/coreruleset/rules/*.conf
# Handle vaultwarden sends with file upload.
request_body /api/sends/* {
max_size 100MB
request_body {
max_size 100KB
# Uncomment this if you want to get a cert via ACME (Let's Encrypt or ZeroSSL).
tls {$EMAIL}
# Uncomment to improve security (WARNING: only use if you understand the implications!)
# If you want to use FIDO2 WebAuthn, set X-Frame-Options to "SAMEORIGIN" or the Browser will block those requests
# By default, Caddy set the following good security practice:
# By default, Vaultwarden actually handle a lot Web Header and caching, which is very nice!
# Enable HTTP Strict Transport Security (HSTS)
Strict-Transport-Security "max-age=15768000;"
#Good Practice Security - Ensure X-Content-Type-Options header is configured and enabled
Referrer-Policy "no-referrer"
#Good Practice Security - X-Content-Type-Options header is configured and enabled
# Disallow the site to be rendered within a frame (clickjacking protection)
X-Frame-Options "SAMEORIGIN"
# Prevent search engines from indexing (optional)
X-Robots-Tag "none"
# Server name removing
-Server
@insecureadmin {
not remote_ip 192.168.1.0/24
path /admin*
redir @insecureadmin /
# Proxy everything to Rocket
reverse_proxy vaultwarden:60278 {
# Send the true remote IP to Rocket, so that vaultwarden can put this in the
# log, so that crowdsec can ban the correct IP.
unifi.one4all.icu {
log
@postinform {
method POST
path /inform
reverse_proxy @postinform unifi-controller:8080
reverse_proxy unifi-controller:8443 {
tls_insecure_skip_verify
@insecureaccess {
respond @insecureaccess "Access Forbidden!" 403
