v2.2.0-rc.1
Ubuntu 18.04.5 LTS
service caddy start
# caddy.service
# for your installation.
After=network.target
User=root
Group=root
ExecStart=/usr/bin/caddy run --config /etc/caddy/Caddyfile
# ExecStart=/usr/bin/caddy run --config /etc/caddy/caddy.json
# ExecReload=/usr/bin/caddy reload --config /etc/caddy/caddy.json
# auto_https disable_redirects
https://haku.site:443 {
level info
tls /etc/letsencrypt/live/haku.site/fullchain.pem /etc/letsencrypt/live/haku.site/privkey.pem {
protocols tls1.2
handle_errors {
rewrite * /404
reverse_proxy localhost:3000
reverse_proxy /split_one http://localhost:12096 {
header_up X-Forwarded-For {http.request.remote.host}
versions h2c
reverse_proxy /split_two localhost:22096 {
reverse_proxy * localhost:3000 {
header_up Upgrade {header.upgrade}
header_up Host {host}
Under certain circumstances, visiting the first two backend (match with path /split_xxx) will get a 400 or 404 respond. By setting the “handle_errors”, I assume caddy will visit the third backedn with “/404” path and return a dynamic pretty error page when 400 or 404 respond is returned by the first two. But actually caddy just pass the original 400 or 404 error respond to client.
Could the “handle_errors” settings be used to accomplish such needs? Or the config was somehow wrong?
No relevant error messages was provided by journalctl -u caddy
caddy log file:
{"level":"error","ts":1599284371.8765345,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"xxx.xxx.xxx.xxx:xxxxx","proto":"HTTP/2.0","method":"GET","host":"haku.site","uri":"/split_two","headers":{"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.83 Safari/537.36"],"Accept-Language":["zh-CN,zh;q=0.9,en;q=0.8,zh-TW;q=0.7"],"Sec-Fetch-Dest":["document"],"Accept-Encoding":["gzip, deflate, br"],"Cache-Control":["max-age=0"],"Dnt":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"haku.site"}},"common_log":"xxx.xxx.xxx.xxx - - [05/Sep/2020:05:39:31 +0000] \"GET /split_two HTTP/2.0\" 400 12","duration":0.000854732,"size":12,"status":400,"resp_headers":{"Server":["Caddy"],"Content-Length":["12"],"Content-Type":["text/plain; charset=utf-8"],"Sec-Websocket-Version":["13"],"X-Content-Type-Options":["nosniff"],"Date":["Sat, 05 Sep 2020 05:39:31 GMT"]}}
handle_errors{
@400 {
expression {http.error.status_code} == '400'
rewrite @400 /404
handle_errors{
rewrite /split_two /404
