Handle and handle_path
I have a working Caddy configuration where Caddy acts as a reverse proxy for my mediawiki site.
=> See working config below
Now I’d like to add more services and I’d like Caddy to route the traffic based on path information in the URI. The above mentions service should run under /wiki. So when I enter cs.domain.net/wiki I excepted the same behaviour as with the running configuration without the /wiki.
=> See not working config below
Now I just see a white page. I expected handle_path to remove the /wiki and work as the first configuration did.
White Screen in Browser
Caddy version: v2.10.2
Caddy runs in a docker container.
Docker.
b. Service/unit/compose file:
  proxy:
    external: true
    image: caddy:latest
    cap_add:
      - NET_ADMIN
      - "443:443/udp"
      - TZ=Europe/Berlin
      - ./conf:/etc/caddy
      - ./site:/srv
      - caddy_data:/data
      - caddy_config:/config
      proxy:
        ipv4_address: 172.28.0.2
  caddy_data:
    external: true
  caddy_config:
    external: true
// Working with https://cs.domain.net
cs.domain.net {
    route {
        basic_auth {
            admin <…>
        reverse_proxy mediawiki:80
    redir https://{host}{uri}
// Not working with https://cs.domain.net/wiki
cs.horstland.net {
	route {
		basic_auth {
			admin <...>
		handle_path /wiki/* {
Can you post curl -v command response?
Edit: also this
Thanks for the fast reply. Here is the curl output. I changed the domain name to domain.net and the IP addresses as well. As far as I can see, the prefix /wiki has not been removed as expected from handle_path command, right?
 curl -v https://cs.domain.net/wiki
* Host cs.domain.net:443 was resolved.
* IPv6: (none)
* IPv4: 355.355.240.83
*   Trying 355.355.240.83:443...
* Connected to cs.domain.net (355.355.240.83) port 443
*  CAfile: /etc/ssl/cert.pem
*  CApath: none
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* (304) (IN), TLS handshake, CERT verify (15):
* (304) (IN), TLS handshake, Finished (20):
* (304) (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / AEAD-CHACHA20-POLY1305-SHA256 / [blank] / UNDEF
* ALPN: server accepted h2
*  subject: CN=cs.domain.net
*  start date: Oct 24 21:01:19 2025 GMT
*  expire date: Jan 22 21:01:18 2026 GMT
*  subjectAltName: host "cs.domain.net" matched cert's "cs.domain.net"
*  issuer: C=US; O=Let's Encrypt; CN=E7
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://cs.domain.net/wiki
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: cs.domain.net]
* [HTTP/2] [1] [:path: /wiki]
* [HTTP/2] [1] [user-agent: curl/8.7.1]
* [HTTP/2] [1] [accept: */*]
> GET /wiki HTTP/2
> Host: cs.domain.net
> User-Agent: curl/8.7.1
* Request completely sent off
< HTTP/2 401
< server: Caddy
< www-authenticate: Basic realm="restricted"
< content-length: 0
< date: Mon, 27 Oct 2025 10:06:59 GMT
* Connection #0 to host cs.domain.net left intact
Working Config without handle_path.
curl -v https://cs.horstland.net
<... same ...>
* using HTTP/2
* [HTTP/2] [1] [:path: /]
> GET / HTTP/2
> Host: cs.domain.net
< HTTP/2 401
< server: Caddy
< content-length: 0
< date: Mon, 27 Oct 2025 10:14:02 GMT
I tried handle with uri strip_prefix and I still get /wiki HTTP/2 in curl.
cs.domain.net {
        route {
                basic_auth {
                        admin <...>
                handle /wiki/* {
                        uri strip_prefix /wiki
Thanks, but these are all returning 401 errors - curl isn’t sending credentials. Could you update it to include them so the site actually responds? Feel free to redact the credentials from the output.
