I have a pfsense router that sends 80 and 443 to caddy on my newly installed ubuntu 20.04 server.
ubuntu 20.04, systemd
I use systemd
ExecStart=/usr/bin/caddy run --environ --config /media/data/1/Caddyfile
After=network.target
ExecReload=/usr/bin/caddy reload --config /media/data/1/Caddyfile
(mycommon) {
try_files {path}.html {path}.htm {path}.php {path}
root * /var/www # Change path & syntax for your OS or your preferred location!
header / {
(mylocations) {
reverse_proxy /grafana* 127.0.0.1:3000 {
****.net {
tls ****@gmail.com # Email for Let's Encrypt Verification
output file /media/data/1/caddy/access.log { # Change path syntax for your OS or your preferred location!
roll_size 10MiB # Rotate after 1 MB
roll_keep 5 # Keep at most 2 log files
output file /media/data/1/caddy/errors.log { # Change path syntax for your OS or your preferred location!
level ERROR
import mycommon # Import code snippet 1 defined above
import mylocations # Import code snippet 2 defined above
http://localhost http://10.0.2.40 {
when using grafana in docker, I’m getting the error “*****.net redirected you too many times” in chrome. This set up previously worked in caddy using
proxy /grafana 127.0.0.1:3000 {
without /grafana
Not sure how to troubleshoot
tried following the migration guide (other resources on the server work fine, this is the last one!), but unable to figure out the problem
